Side bar module not showing products
- Rollerskate
14 years 10 months ago #30040
by Rollerskate
Side bar module not showing products was created by Rollerskate
My side bar module is no longer showing my products and I'm not quite sure why.
www.therollerskate.com/articles/5-reason...rters-are-a-bad-idea
14 years 10 months ago #30050
Replied by nicolas on topic Re: Side bar module not showing products
It's probably because of the options of your module
Hard to say more without looking at them. Could you do a screenshot of the hikashop options page of that module ?
- Rollerskate
14 years 10 months ago #30051
by Rollerskate
Replied by Rollerskate on topic Re: Side bar module not showing products
14 years 10 months ago #30057
Do you have products directly in that "All photos" category ?
If not, it's normal that it is not displaying any product.
You should change the "sub element filter" to "all sub elements" filter to have the products of its sub categories displayed.
- Rollerskate
14 years 10 months ago #30061
by Rollerskate
All Subelements didn't work, and yes, I do have products directly in ALL Photos.
14 years 10 months ago #30062
I don't see the "Order photos" module at all on that page (I thought that you were talking about the module "order prints"). That means that the problem comes from the joomla options of your module. Either the module is disabled or set to not display on that menu, or for the current user group...
- Rollerskate
14 years 10 months ago #30063
by Rollerskate
Got it, I had the Type of Content "Category" not "Product." Now that I switched it to "Product" it's working fine.
Time to create page: 0.203 seconds
