where could i read about manufacturers?
14 years 9 months ago #31998 by progreccor
I don't see any documentation about manufacturers...
how could work with them?
could i show the manufacturer on the product page?
Я здесь добровольно!
14 years 9 months ago #32027 by nicolas
There is not much to read about it.
Actually here is want you can do with that:
1. manage your manufacturers via the menu Products->Manufacturers
2. assign a product to a manufaturer when you edit a product
3. create products listing for manufacturers (it's like for categories but in the parent category of the menu/module, you need to select a manufacturer).
4. create manufacturers listings (it's like for categories but in the parent category of the menu/module, you need to select the main manufacturer).
There is no option to display the manufacturer on the product page. However, if you don't need to do point 2 or 3, you can create a custom product field via the menu Display->Custom fields and make it a manufacturer dropdown. You will be able to choose the manufacturer on the product edition page and display the selection on the product page:
www.hikashop.com/en/support/forum/4-how-...on-product-page.html
Time to create page: 0.130 seconds
