Characteristics and Options for Product Item
14 years 9 months ago #33255
by bal3nsd
Characteristics and Options for Product Item was created by bal3nsd
Currently I am setting up a site for a small printing company. I am needing some help on how I may be able to set up the Characteristics and Options for each product.
First, I set up a characteristic for "Quantity" each variant having a specific price. This product also has other options such as paper stock and coating, each adding to cost depending on selection. Can I set up multiple characteristics? I tried but I was not able to manage variants for other characteristics. I get a "No value added" on other characteristics.
Later, I tried to add them as products but realized that I would have to enter each option individually. Then a dropdown menu show up with "no" or "yes+$xx.xx" option to choose from.
Is there a way to display multiple options in dropdown menu form? With a selection adding to the total price, instead of replacing it.
Or if you could suggest a better way of tackling this I'd appreciate your help. Thanks!
JK
JK
14 years 9 months ago #33285
Replied by nicolas on topic Re: Characteristics and Options for Product Item
You can have more than one characteristic, yes. If you get the "No value added" you need to follow the documentation here:
www.hikashop.com/en/support/documentatio...html#characteristics
Yes, you can have multiple options for options
For that, you need to add a characteristic for your option. That's explained there:
www.hikashop.com/en/support/documentatio...ct-form.html#options
14 years 9 months ago #33432
by bal3nsd
Replied by bal3nsd on topic Re: Characteristics and Options for Product Item
Thanks, After reading it makes a lot more sense. Will try and let you know how it works out. Thanks again! great product!
Time to create page: 0.139 seconds
