Menu problem
14 years 9 months ago - 14 years 9 months ago #34213 by ener
Menu problem was created by ener
Is it possible to make menu automatically, when new category is created, or I have to always add new menu item from Joomla Menu manager?
And if anbody knows how to make sliding menu, like in demo page?
Last edit: 14 years 9 months ago by ener.
14 years 9 months ago #34240 by nicolas
Replied by nicolas on topic Re: Menu problem
Yes it's possible. The sliding menu you see on our demo website was done with the HikaShop module which is included in HikaShop by default (plus a bit of CSS to adapt it to the template of the demo website).
To do that you first need to create a category listing module as explained there:
www.hikashop.com/en/support/documentatio...ml#categories_module
Then, make sure that your module has the same hikashop options as the module on our demo website:
www.demo.hikashop.com/administrator/inde...odules&task=edit&cid []=55
14 years 9 months ago - 14 years 9 months ago #34277 by ener
Replied by ener on topic Re: Menu problem
Ok menu is working now. But I have products in subcategories and when I click on some subcategories in menu, then I should see products, but they are not displayed.
I tested it with another menu, and there are all products displayed. What might be wrong?
14 years 9 months ago #34282 by ener
Ok I got it and got another problem.
If I have menu link with subcategories, like in demo, that if I click on main category, then appears subcategories without going to product page.
And maybe I have some categories WITHOUT subcategories, then I cant get to product page. Seems like if I want to use this menu, I always need to add some subcategories.
There are similar option in module "link on main categories". Can I do so, if there are subcategories then it slides without changeing page, and if just main category, then after click it directs me to product page.
14 years 9 months ago #34313 by nicolas
If you want to have a menu going to the products listing page of a specific category, you can do so with a hikashop products listing type of menu.
There is no option to do another sliding system than the one already in place for categories listing modules.
Time to create page: 0.178 seconds
