Coupon Configuration Problems
14 years 9 months ago #34244 by condorazul
I created a Coupon choosing coupon in options. The problem i have is that i want to send this coupon to a client and then he has to input it on the coupon field, but when i create the coupon and surf the web anononymously, choose one product and go to checkout, the coupon is already there, it says your coupon is (coupon_name) and it is fixed there, and if i press the eliminate coupon button, nothing happens.
14 years 9 months ago #34263 by nicolas
It's probably because you turned on the "auto load" option of your coupon. Please make sure that this option is turned off and try again.
14 years 9 months ago #34274 by condorazul
that was it thank you
Time to create page: 0.165 seconds
