Model class categoryModelCategory not found in fil
14 years 8 months ago - 14 years 8 months ago #35226
by bruntt
Model class categoryModelCategory not found in fil was created by bruntt
I saw this issue discussed
here
, but the fix recommended did not work for me.
You can see the error message here .
The error displays when I create a Hikashop "Category Listing" menu item. There is no error if I do a "Product Listing" menu item.
Also, the category icons do show up after the error message, but each category has a product in it and yet not product displays when I click on a category.
I'm using Joomla 1.7.3 and the most recent Hikashop Starter 1.5.5
How can I fix this?
How can I fix this?
Last edit: 14 years 8 months ago by bruntt.
14 years 8 months ago #35228
Replied by nicolas on topic Re: Model class categoryModelCategory not found in fil
What other extensions do you have installed ?
14 years 8 months ago #35234
by bruntt
Replied by bruntt on topic Re: Model class categoryModelCategory not found in fil
I just disabled the "Frontend User Access" plugin, which I'm not using anyway, and the problem went away.
Thanks for pointing me in the right direction.
Time to create page: 0.153 seconds
