Product images not opening in a popup
14 years 9 months ago #36503 by obsolum
I'm sorry for asking so many questions lately, but I'm finetuning everything before I launch the website.
When I click on product images they open in a seperate tab. I thought this was default HikaShop functionality but apparently they are supposed to open in a popup / lightbox? They've never done that for me. Do I need an additional plugin in order for that to work?
Also, in the documentation in the part about Images there is a screenshot showing "Full image popup max width / height" fields. I don't have those. Were they removed?
14 years 9 months ago #36556 by nicolas
That should work like that by default, unless you have some javascript errors on your pages.
You can also use this www.hikashop.com/en/support/documentatio...ox-media-player.html to have the images open with shadowbox media player instead of the default joomla popup system. It might help avoid the problem.
These options are not useful anymore and were removed yes.
14 years 9 months ago #36613 by obsolum
Okay, that was simple enough.
Got it working now, thanks!
