Weird problem with borders
14 years 8 months ago - 14 years 8 months ago #36662 by obsolum
Hi, me again. I'm nearing completion of the website so hopefully this will be one of my last questions for a while :)
On the category listing page the rounded borders go through the images (see attached screenshot). This doesn't happen if I keep the image size 100x100 but I'd like it to be larger.
Is there any way I can fix this?
Thanks!
Last edit: 14 years 8 months ago by obsolum.
14 years 8 months ago #36731 by nicolas
On your listing menu, you have an option to define the number of columns of the listing. If you reduce the number of columns, each column will have more space for itself, and thus, you will be able to increase the thumbnails size more before it goes over the border.
In the same manner, you should reduce the margin option of your menu to reduce the space between the columns and thus have bigger columns.
Time to create page: 0.185 seconds
