Move products to Joomla 2.5
14 years 9 months ago #37239 by HappyHammer
Can you tell me the easiest way to move all of my products and categories to a new Joomla 2.5 build. Do I need to upgrade the version of Hikashop on the old version of the site first?
HH.
always look on the bright side....
14 years 9 months ago - 14 years 9 months ago #37244 by woonydanny
I will try and recall this from my memory.
1. upgrade your hikashop version on J1.5 site to latest version!
2. I use SP Upgrade to migrate site from J1.5 to J2.5, this will migrate all your core joomla stuff.
3. On new J2.5 site install HikaShop
4. then export hikashop tables from J1.5 database with phpmyadmin
5. import those tables into the J2.5 database with phpmyadmin
6. as the hikashop versions are the same on both J1.5 and J2.5 sites it should all work then B)
Last edit: 14 years 9 months ago by woonydanny.
14 years 9 months ago #37249 by woonydanny
Just found these pretty useful articles on migrating J1.5 to 2.5 from the team over at Jomsocial. There are 8 articles that explain the processes, reviews the different migrators and what you need to know - www.jomsocial.com/blog.html
The article that explains the process for migrating jomsocial would be the same for hikashop - www.jomsocial.com/blog/migrating-jomsoci...-into-joomla-25.html
14 years 9 months ago #39174 by woonydanny
Also, just thought that after you install HikaShop on the new J2.5 site, you will need to delete all the Hikashop database tables before importing the J1.5 hikashop tables.
13 years 7 months ago #98944 by brentwilliams2
Hi woonydanny,
I used your instructions and had no problem on my local server. But I had an issue with importing to my shared server. Specifically:
Error
SQL query:
CREATE ALGORITHM = UNDEFINED DEFINER = `XXXXXXX_XXXXXXX`@`localhost` SQL SECURITY DEFINER VIEW `jos_hikashop_click_view` AS SELECT `a`.`user_id` AS `user_id` , SUM( `b`.`click_partner_price` ) AS `click_price`
FROM (
`jos_hikashop_user` `a`
LEFT JOIN `jos_hikashop_click` `b` ON ( (
`a`.`user_id` = `b`.`click_partner_id`
AND (
CASE WHEN (
`a`.`user_currency_id` =0
THEN 2
ELSE `a`.`user_currency_id`
END ) = `b`.`click_partner_currency_id`
WHERE (
`a`.`user_partner_activated` =1
AND (
`b`.`click_partner_paid` =0
GROUP BY `b`.`click_partner_id` ;
MySQL said:
#1227 - Access denied; you need (at least one of) the SUPER privilege(s) for this operation
Any suggestions?
13 years 7 months ago #99015 by nicolas
The _view "tables" are not necessary. Simply delete them before and try again.
13 years 7 months ago #99020 by brentwilliams2
Thanks for the response, Nicolas. I ended up having my hosting company import for me.
