Problem installing on localhost
- FranksBank
14 years 7 months ago #38461
by FranksBank
Problem installing on localhost was created by FranksBank
Hi folks,
New boy here; and a bit stuck.
For info, my specs are:
Joomla! 2.5.1
Hikashop Starter (com_hikashop_starter_1.5.6_2012-02-06.zip)
I can't install on localhost; message I'm getting is: "Unable to write entry".
I've successfully installed from the same file to the web server, so I know the zip archive is fine, and I've had no problems with any other extensions (I even installed and removed a few just to check my localhost setup is all ok, which it is).
I've been through the fixes on the support page, but it still won't work. Using the 'fix' that enables better error reporting, the only thing I notice is a change of 'slash' direction in the string when trying to 'Install from Directory'. The error report is as follows:
-1 - An error has occurred.
Copy failed C:\Users\Frank\The Workshop\Websites\DevSERVER_xampp\htdocs\test\tmp\hikashop\back\extensions/plg_hikashoppayment_bf_rbsbusinessgateway/bf_rbsbusinessgateway_configuration.php => C:\Users\Frank\The Workshop\Websites\DevSERVER_xampp\htdocs\Allsites\test\administrator\components\com_hikashop\extensions/plg_hikashoppayment_bf_rbsbusinessgateway/bf_rbsbusinessgateway_configuration.php
Notice the change from '\' to '/' after "extensions". Is that normal? Seems a bit odd to me.
Very grateful for any assistance anyone can offer. As an infant Hikashopper I need, from scratch, to learn the workings of Hikashop and how to integrate it into pages; I would prefer to do so on my local machine rather than across the web.
Hope someone out there can help!
Cheers,
Frank
Joomla! 2.5.1
Cheers,
Frank
14 years 7 months ago #38634
Replied by nicolas on topic Re: Problem installing on localhost
It's strange that this happens in the middle of the install process. Usually file copy errors are due to either access rights on the folders or disk space running out. Since you're on a windows computer, you should not have a problem with the access rights.
HikaShop has a lot of files compared to most joomla extensions so the installation process can have problems that others don't because of that.
The simplest if you already have it installed on an online website is to backup your online website and restore it on your local computer. You can do that with akeeba backup.
The following user(s) said Thank You: FranksBank
- FranksBank
14 years 7 months ago #39036
by FranksBank
Replied by FranksBank on topic Re: Problem installing on localhost
Thank you Nicolas that was very helpful!
Although we don't know why the problem occurred, the workaround you suggested has done the trick, i.e. I found and grabbed Akeeba (first time user there too; brilliant system and documentation) and created a backup. Now having 'restored' that onto localhost everything's working perfectly. I can start learning Hikashop now
Many thanks again.
Many thanks again.
Time to create page: 0.209 seconds
