How to: format descriptions of product imports
15 years 10 months ago #4135 by gemmill
Currently sussing out the file import file, and am struggling with getting the text descriptions to drop onto multiple lines.
Can this be done? or do I have to upload it, then format it?
15 years 10 months ago #4136 by nicolas
You can use quotes to have multiple lines in a field:
product_code,product_description
my_code,"my
product
description
on
several
lines"
15 years 10 months ago #4137 by gemmill
any chance of doing it from within an excel csv?
tried via text field too... got the following error...
15 years 10 months ago #4138 by nicolas
Interesting. You found a bug in the import.
It doesn't work if the last column is on several lines.
You can replace the file administrator/components/com_hikashop/helpers/import.php by the one in the archive to fix the problem.
The text field example I wrote is just to show you how the system handles several lines.
Excel CSV are supported as well.
15 years 10 months ago #4139 by gemmill
i'll check it out in a few days...
Have a happy Christmas :)
15 years 10 months ago - 15 years 10 months ago #4141 by gemmill
with the csv import... how do I get text on the next lines... i did the usual "alt+enter" ... but this doesn't work
**** EDIT***
this does move the lines down on execl... but not when imported.
also, even when using the text editor / imort it still puts them all on the same line.
****** The text i was trying to import *******
product_code,product_description,categories
testnew1,"my
product
description
on
several
lines",11
Last edit: 15 years 10 months ago by gemmill.
15 years 10 months ago #4142 by nicolas
Entering several lines in Excel isn't really related to HikaShop :)
From what I know it's ctrl+enter or ctrl+alt+centre on macs.
Some users say alt+enter works for them...
Just try the different combinations. There's got to be one working but apparently it depends on your version of Excel.
15 years 10 months ago #4143 by gemmill
sorry yes I meant I put the text on more lines in excel, but didn't work on the import.
15 years 10 months ago #4144 by nicolas
Could you edit the CSV with a text editor and copy/paste here a few lines so that we can test on our end ?
Did you get any error ?
15 years 10 months ago #4145 by gemmill
no error, it just didn't split the lines.
i'll do it now.
my csv file has all the fields... but not populated yet as i'm just trying to get it worked out before I start putting in data.
15 years 10 months ago #4146 by gemmill
product_parent_id,product_name,product_description,product_quantity,product_code,product_published,product_hit,product_created,product_sale_start,product_sale_end,product_delay_id,product_tax_id,product_type,product_vendor_id,product_manufacturer_id,product_url,product_weight,product_keywords,product_weight_unit,product_modified,product_meta_description,product_dimension_unit,product_width,product_length,product_height,product_max_per_order,price_value,price_currency_id,price_quantity,files,images,categories,related,size
,testnew,"""my description
on multiple
lines""",,testnew2,yes,,,,,,,,,,,0.1,,,,,,,,,,12,,,,thumbnail/umm.jpg,10,,
hmmm... it appears there is extra quote marks around the text...
i'll try removing this
15 years 10 months ago #4147 by gemmill
I got rid of the "s from the csv... so the code is now this...
,test3,"my description
on multiple
lines",,testnew3,yes,,,,,,,,,,,0.1,,,,,,,,,,12,,,,thumbnail/umm.jpg,10,,
but.... this doesn't work either....
15 years 10 months ago #4148 by nicolas
This yelds an error because of the space in the image column name as you have "imag es".
After correcting that, it imported correctly on my end in several lines.
Mmmm. I'm feeling that you're missing something:
The description of products is displayed in HTML. So return characters are not interpreted by the browser. If you want text on several lines in the description, you should use HTML tags. For example by adding <br/> tags.
Also, you might be tricked by your HTML editor. Some Joomla HTML editors will remove the return characters when displaying the description. If you set the editor option of hikashop to no editor, or if you look directly in the database, you will see the return characters.
15 years 10 months ago - 15 years 10 months ago #4149 by gemmill
wow thats weird... i just checked the csv file, and there is no space in images.
when i paste the file text here... there is no space,
but once submitted, the space appears.
when pasted in the "import from text area" with no space in images, it doesn't split them.. i'll try using html
15 years 10 months ago - 15 years 10 months ago #4150 by gemmill
ok so back to it after the break, I hope you have had time to relax.
this is what i'm getting at the moment... before even trying to get it right in the .csv file.
This is the text import I tried.
15 years 10 months ago - 15 years 10 months ago #4297 by gemmill
gives me this.. which is correct,
15 years 10 months ago #4298 by gemmill
But is displaying this.....
15 years 10 months ago - 15 years 10 months ago #4302 by nicolas
What if you try with <br/> instead of </br> which is wrong ? It might have been removed by the text editor at one point because it's not valid HTML.
Last edit: 15 years 10 months ago by nicolas.
15 years 10 months ago #4304 by gemmill
same result.
Sorry to be such a pain.
15 years 10 months ago #4305 by nicolas
Ah, I have an idea, it's probably the input filtering which strips the HMTL.
Could you change the line
$content = JRequest::getString('textareaentries');
by the line
$content = JRequest::getVar('textareaentries','','','string',JREQUEST_ALLOWRAW);
in the file administrator/components/com_hikashop/controllers/import.php ?
Time to create page: 0.106 seconds
