Confused, help!. Out of stock products.
14 years 7 months ago - 14 years 7 months ago #41363 by ssaxton
No matter what I do I cannot get Hikashop to stop displaying out of stock products that have variants.
Here is the issue. If the product has variants and I set the main products quantity to "unlimited" then it shows whether or not the variants have items in stock. If I set the main product to "zero", then it does not show up regardless how much quantity the variants have. Is there a way around this?
Thanks,
Steve
Last edit: 14 years 7 months ago by ssaxton.
14 years 7 months ago #41547 by nicolas
Make sure that you're using the latest version of HikaShop and set the real quantity in the main product (the sum of all the variants).
Then, when the variants are bought/refunded, the main product quantity should change at the same time as the variant quantity changes and thus it should work like you want.
14 years 7 months ago #41745 by ssaxton
Thanks and Sorry for late reply.
Just one more thing; Can you tell me how to alter the text for "No Stock"?
Steve
14 years 7 months ago #41746 by ssaxton
Nevermind, found it in the languages file under configuration.
Time to create page: 0.157 seconds
