Problem with importing GBP £ sign
14 years 6 months ago #43841 by PhilP
I have been uploading and creating some tabbed notes in our product store. When I bring in via a text area import everything works fine, as per image1.
However, when I import the identical dataset via a csv file, the tabs do not get created. See image 2.
My test dataset is below. The problem seems to be with the import of the £ currency sign.
I have a lot of these notes to do so I really need to import from a file rather than pasting into the text area.
Advice appreciated.
Phil P.
product_name,product_code,product_description
Test Product Main,xxTest_Product_Top,"
<p>{tab=Test Tab 1}</p>
<p>This is text on the first tab</p>
<p>{tab=Test Tab 2}</p>
<p>This is text on the second tab £99</p>
<p>{/tabs}"
14 years 6 months ago #44034 by nicolas
It might be coming from an encoding mismatch. Your file must not be encoded in UTF8 or it is encoded in a different encoding than what you specifies in the encoding option of the import screen. So you should check the encoding of your CSV file.
14 years 6 months ago #44076 by PhilP
Yes - that was the problem. I have just re-imported the file leaving the file charset as 'unknown' and the £ sign now displays correctly.
Thanks for your help.
PhilP
Time to create page: 0.220 seconds
