Product with same picture
14 years 6 months ago - 14 years 6 months ago #43974 by fnuus
I'm new here and i will try to write my problem in my best englisch.
I want to add 64 products in the Hikashop Free. All products have the same picture but a different description. now is must upload 64 times the same picture.
Is it possible to do that simple. For example with the picture name ?
I get now this message when i want to add a picture with name : The file is not added via the browse button.
Thanks for the reactions,
Fred
Last edit: 14 years 6 months ago by fnuus.
14 years 6 months ago #44172 by nicolas
You can link your image to the other products via the Products->Import menu. Select the "import from textarea" option and enter a text like that:
product_code,images
...etc...
where you put the real product code of your products, and the image will be linked automatically to your products after you click on "import".
The following user(s) said Thank You: fnuus
Time to create page: 0.124 seconds
