Problems with import CSV
14 years 5 months ago - 14 years 5 months ago #47390
by tefun
Problems with import CSV was created by tefun
When i import items from CSV Hikashop give error:
Where is problems?
I think, that is may be descriptions of the items, becouse they include commas
I give CSV file for import, look it please
____________________-
That is allright
I make this problem
Fatal error: Call to a member function setQuery() on a non-object in Z:\home\localhost\www\katalog\administrator\components\com_hikashop\helpers\import.php on line 722
Where is problems?
That is allright
I make this problem
Last edit: 14 years 5 months ago by tefun.
14 years 5 months ago #47404
by Xavier
Replied by Xavier on topic Re: Problems with import CSV
Hi tefun,
The problem is not due to the commas in the description. You can put commas.
I think it come from your encoding type, or something like that.
Your file only has special characters.
14 years 5 months ago #47418
Replied by nicolas on topic Re: Problems with import CSV
Please replace the two occurrences of the code:
$this->database
$this->db
in the file administrator/components/com_hikashop/helper/import.php and it should then work.
$this->database
$this->db
The following user(s) said Thank You: tefun
14 years 5 months ago #47456
by tefun
Replied by tefun on topic Re: Problems with import CSV
Thanks!
But i did this
My CSV file had not needed fields. I filled in the fields and that is allright!
But, thank you for replay
But i did this
Time to create page: 0.262 seconds
