- Thank you received: 1
Reduce the space between two products in invoice.
- Scheinbacher
14 years 5 months ago #47394
by Scheinbacher
Reduce the space between two products in invoice. was created by Scheinbacher
could you please tell me where and how can I reduce the space (hight) between two product in the customer mail and invoice (backend & frontend). I have already try to reduce the hight of the table with (<TD HEIGHT="xxx">, but it seems not to effect the space between two products.
Thank you.
Thank you.
14 years 5 months ago #47545
by Xavier
Replied by Xavier on topic Re: Reduce the space between two products in invoice.
Hi Scheinbacher,
For the order, try to change:
To enlarge price column.
I think the space between two products come from your template. Try to edit this property in your CSS file:
For the email, in HikaShop > Configuration > Emails, edit the "order creation notification" email.
Edit:
To add a class:
And try to edit this class property in your CSS file.
.hikashop_order_item_total_value{
width: 30px;
.adminform td{
Edit:
foreach($data->cart->products as $item){
<tr>
<td>
<tr>
<td class="order_creation_notification_item">
Time to create page: 0.159 seconds
