Assign Custom product fields to select products
- bluetonguedesigns
14 years 5 months ago #48396
by bluetonguedesigns
Assign Custom product fields to select products was created by bluetonguedesigns
Hi, just installed Business edition for a client, never had a need for custom product fields, now I do.
I managed to create the custom field ok, but not sure how I get it to be "Assigned" to selected products only (Not across the board, can it be done by category?) and how to make it display on the product page and then into checkout etc?
14 years 5 months ago #48400
Replied by nicolas on topic Re: Assign Custom product fields to select products
You should create custom fields of the table "item", make them published on the front end and you will see them. In the options screen of the custom fields, you'll find a categories area where you can restrict the custom fields to only some categories.
- bluetonguedesigns
14 years 5 months ago #48403
Replied by bluetonguedesigns on topic Re: Assign Custom product fields to select products
Thanks Nicolas, was making it of the type product so it was not showing up.
Don't suppose there is an option to have the custom field appear depending on the selection of an option?
Like...
Personalised message - yes (Show Field)
Personalised message - no (Don't show field)
Like...
14 years 5 months ago #48434
If both are custom fields, you can use the "Display limited" option for that.
- bluetonguedesigns
14 years 5 months ago #48462
Nope, one is an option as it needs to add a small cost.
14 years 5 months ago #48544
In that case that's not possible.
Time to create page: 0.189 seconds
