Not Logging In After Register
14 years 5 months ago #48817 by bars92
hey again.
I am using the register menu to register before shopping, and after the register the user needs to be logged in.
The problem is, he is not.
It happened to me before, and i was because the user register contained fields that was required but not in the front-end.
Now i tried everything i could think of and i cant seem to understand why.
If you have any suggestions, please share.
Thanks in advance.
14 years 5 months ago #48840 by nicolas
The user registration form does not auto log users in joomla.
If you want to do that, you'll have to use an auto login plugin:
extensions.joomla.org/extensions/access-...te-access/auto-login
14 years 5 months ago #48853 by bars92
I know in the checkout the registration in the login step does login to joomla.
Anyway, when i install and try it, it gives me Invalid Token and it does not save the Hikashop custom fields.
What do i do now?
14 years 5 months ago #48873 by nicolas
Can you give a link to that page so that we can see that ?
14 years 5 months ago #48880 by bars92
Here is the link: zristar.com/en/register
fill in and click register you will see a Invalid Token by the plugin and the little line in the top says whos logged in and his Refferal custom field you entered.
14 years 5 months ago #48899 by nicolas
That's not normal. Once logged in, HikaShop doesn't even display the registration form but redirects to the user control panel when trying to display that page.
Also, there is no token check in HikaShop, and even if it were, it should match as we send the current one.
It sounds like you have a cache problem on your website.
Please check that the cache of the joomla configuration, the cache plugin via the plugins manager and the cache option of your template (if there in the options of the template) are all deactivated and try again.
14 years 5 months ago #48932 by bars92
i couldnt understand how to deactivate cache, but if you ment purge cache then it didnt help..
I noticed the plugin uses onAfterUserCreated but Hikashop custom fields are not saved so plug in must have been interuppting Hikashop..
14 years 5 months ago #48987 by nicolas
What plugin ?
To turn off cache, you need to do three things:
Global Configuration--> System-->Cache Settings-->Cache
Please select 'No';
Extensions-->Plugin Manager-->System - Cache
Please disable the plugin-"System-Cache" .
Extensions-->Templates Manager-->YOUR TEMPLATE
Please look for a cache option in your template's options.
14 years 5 months ago - 14 years 5 months ago #49117 by bars92
All cache options already set to off..
I meant the auto login plugin that might interuppt Hikashop.
Have you ever heard about someone that this plugin worked using Hikashop?
EDIT: i checked the auto plugin and notice i get error 1 when trying to login. Trying to figure out what does it mean.
Last edit: 14 years 5 months ago by bars92.
14 years 5 months ago #49199 by nicolas
No that's the first time someon asks to auto login users after registration from the registration page of HikaShop.
Most of the time, they only use the registration inside the checkout. In that case, HikaShop handles automatically the auto login.
What error do you get with the auto plugin ?
14 years 5 months ago #49337 by bars92
I dont know what the error is, but when i run the JApplication::login it retruns 1 which means error.
but i couldnt see what 1 means.. Perhaps you would know.
14 years 5 months ago #49400 by nicolas
I don't know about that. Could you do a screenshot ?
14 years 5 months ago - 14 years 5 months ago #49408 by bars92
attached a picture of the plug-in.
The line: $error = $app->login($credentials, $options); returns 1
and all Hikashop custom fields are NULL, which cause the plugin to log in, but all of the user custom fields are empty.
14 years 5 months ago #49437 by nicolas
No I mean a screenshot of the error message.
14 years 5 months ago #49459 by bars92
there is no error message i just print the $error as you see in the picture.
14 years 5 months ago #49503 by nicolas
So do you mean that the auto login plugin does not work ?
14 years 5 months ago #49541 by bars92
It does work, strangly the user is connected but hika fields are empty as if Hikashop register did not work and i get an error from the plugin.
14 years 5 months ago #49609 by nicolas
As yes. That's because the saving of address fields is done after the user has been saved in Joomla. And that plugin is triggered in between and it redirects the page at that point. You should try to remove the redirect lines of code in the plugin and that should help.
12 years 5 months ago #152925 by coolbugs
have you got this working? I seem to have problem saving the user information with the autologin
12 years 5 months ago #152940 by nicolas
As I said in my last post, you should remove the "redirect" lines in the auto login plugin file so that it doesn't redirect the user to another page before HikaShop process the user information.
The following user(s) said Thank You: coolbugs
Time to create page: 0.287 seconds
