When comparing products, show description as well
14 years 4 months ago #49512
by yyounan
When comparing products, show description as well was created by yyounan
When comparing products in the business edition, the table displays product name, image, price, and custom fields. How can I add product description as well?
14 years 4 months ago #49595
Replied by nicolas on topic Re: When comparing products, show description as well
You will have to edit the file "compare" of the view "product" via the menu Display->Views and add some code in the view to display it.
14 years 4 months ago #49621
by yyounan
Replied by yyounan on topic Re: When comparing products, show description as well
Can you tell me the code to add? what is the field name that I should echo?
14 years 4 months ago #49695
you should use such code:
<?php echo $element->product_description; ?>
14 years 4 months ago #49714
by yyounan
Time to create page: 0.165 seconds
