- Thank you received: 2
Custom shipping zones and calculations, HELP!
14 years 4 months ago #52461
by karlvann
Custom shipping zones and calculations, HELP! was created by karlvann
My skill level - I don't know how to code at all, however I have always gotten away with making changes to existing code to suit my needs.
I use custom shipping zones for all of my products. I see that I can enter a Manual shipping method which has a minimum and maximum postcode.
e.g. I know I can do it this way
sydney metro 2000 - 2050
create a new custom shipping
sydney metro 2061
sydney metro 2070 - 2090
However I would have over a thousand custom shipping methods If I do it this way.
My question is, can I do something like this manually somewhere
Sydney Metro 2000-2050, 2061, 2070-2090 and so on
Also my calculations are worked out like this
per kilo weight Product weight flat rate
e.g. 0.38 X 70 + 10 = $36.46
is this possible with Hikashop?
I am just started out with hikashop yesterday, It's a relief compared to what I have been using and I'm pretty sure I'll be buying it for my site if I can get these things worked out.
sydney metro 2061
14 years 4 months ago #52521
Replied by nicolas on topic Re: Custom shipping zones and calculations, HELP!
That would indeed require to change the code as it is not possible with the options provided.
The plugin file path is plugins/hikashopshipping/manual.php
You will have to edit the code in the function onShippingDisplay.
What do you mean by "per kilo weight Product weight flat rate" ?
14 years 4 months ago #52523
by karlvann
Replied by karlvann on topic Re: Custom shipping zones and calculations, HELP!
Oh, The formatting stuffed up (spaces) and it looks like gibberish now
It's just how my calc is setup, doesn't matter, I've found a way around it.
Thanks for the response, I'll have to figure out a way to change the code.. Thanks for your time. Kind regards, karl..
Time to create page: 0.167 seconds
