Is There An Override For Cart Module
14 years 4 months ago #52717 by MyWorld
How can I override the "HikaShop Cart Module" please. I checked the views but I don't see it there.
I'd like to change the text layout in the module. Currently it looks like this this:
2 items for $15.95
I'd like to change it to look like this:
2 items for
$15.95
Thanks!!
14 years 4 months ago - 14 years 4 months ago #52783 by Mohamed Thelji
I think that you can do it if you :
- Go to "Hikashop->System->Language"
- Edit the "English (United Kingdom)" Language file
- Change the line :
X_ITEMS_FOR_X="%s items for %s"
to
X_ITEMS_FOR_X="%s items for </br> %s"
Hope this will help you.
Last edit: 14 years 4 months ago by Mohamed Thelji.
The following user(s) said Thank You: MyWorld
14 years 3 weeks ago #65305 by olivnewton
but what if someone really wants to override the cart module???
i copied mod_hikashop_cart/mod_hikashop_cart.php into mytemplate/html
and made changes to mod_hikashop_cart.php, but it wouldnt override...
what am i doing wrong?
14 years 3 weeks ago #65314 by nicolas
You should not do it like that.
If you want to override the cart module, you can edit the file "cart" of the view "product" via the menu Display->Views.
14 years 3 weeks ago #65385 by olivnewton
i see! thanks for the quick reply. where can i find those files inside joomla-file-structure? i would like to edit them manually with my code-editor, rather than via display->views. this way i can better comment and keep track of changes i made.
also, if i decide to buy the styles-pack, will this override my changes in display->views or do i then need to re-do all changes on this certain template i will install again?
14 years 3 weeks ago #65465 by nicolas
It's the file components/com_hikashop/views/product/tmpl/cart.php
But you should not edit directly the file as you will loose your changes when you update HikaShop.
If you do it via the interface on the other end, you won't loose your changes as they will be stored as view overrides in the html folder of your template.
The styles pack won't override your view files. They just contain CSS and images to style the different elements of HikaShop bu they don't change the structure.
14 years 3 weeks ago #65468 by olivnewton
ok, i understand. then i can create my own view-overrides in my template folder and make changes there with my code-editor?
14 years 3 weeks ago #65621 by nicolas
Yes. Just save the view file once in the Display->views menu and you will get the file in the good folder in the template and you can just edit the file directly with your editor.
14 years 2 weeks ago #65772 by olivnewton
but i dont have to save it in backend, if i copy manually the file into the template, it will still be marked as "customized" in the backend, isnt it?
14 years 2 weeks ago #65907 by nicolas
Yes, that's indeed the case :)
It's just to make it easier for non programmers or beginners.
14 years 2 weeks ago #65977 by olivnewton
great thanks!
Time to create page: 0.356 seconds
