- Thank you received: 3
Move Product Title and Add Link to Submit Review
14 years 3 months ago #53743
by michael
Move Product Title and Add Link to Submit Review was created by michael
Was thinking to move the product display title from top to right column, and move the 5 stars down to bottom of the right column (below shopping cart), and add a link say "Submit your review" then link to the bottom of the page, so customer aware that.
Kindly point out the right location to do these 2 tasks, and the right way to add a texts link.
Example page
Alternately, if can create tabs in description area, so can split product details/photos and reviews/comments in difference tabs will be better. I tried free tabs in Joomla, but once I select product's option in frontend, the tabs cannot function well.
Hope Hikashop new release have this tabs feature
Thank you!
Example page
Thank you!
- Thank you received: 1778
14 years 3 months ago #53759
by Mohamed Thelji
Replied by Mohamed Thelji on topic Re: Move Product Title and Add Link to Submit Review
Hello michael,
1. I think that you'll find your answer there
- Go to "Hikashop->System->Configuration->Display"
- Set your "Layout on product page" to Tabular
Hope this will help you.
2. You'll maybe have to :You need to edit the file "show_default" of the view "product" of your front end template via the menu Display->Views. You will see there the left/right/top/bottom areas mentioned in the CSS.
14 years 3 months ago #53790
by michael
Replied by michael on topic Re: Move Product Title and Add Link to Submit Review
Hi Thelji,
Thanks for your help! About tabs, I have used tabber as suggestion in other thread, and working well
But, about the title, has moved to right column, but once the title exceeded a specific length, the whole right part will dropped below image.
How to set wrapping of the title, cannot find any thread here.
Thank you!
Thank you!
14 years 3 months ago #53864
Replied by nicolas on topic Re: Move Product Title and Add Link to Submit Review
You need to force the width on the right area with some CSS:
.hikashop_product_right_part{width: 50%;}
14 years 3 months ago #53895
by michael
Fantastic
Thank you so much, Nicolas !
Time to create page: 0.183 seconds
