carousel Module?
14 years 3 months ago - 14 years 3 months ago #54434 by davemalton
carousel Module? was created by davemalton
childrenstoystoystoys.com/
I dont understand what I am doing wrong, I have it set up as it says in the "Infinite slide" documentation I actaully think I used the exact paramaters? Any Help would be appreciated. Thanks.
Dave
Last edit: 14 years 3 months ago by davemalton.
14 years 3 months ago #54456 by nicolas
Replied by nicolas on topic Re: carousel Module?
Could you do a screenshot of the options of your module ?
14 years 3 months ago #54582 by davemalton
Replied by davemalton on topic Re: carousel Module?
its added.
Dave
14 years 3 months ago #54607 by nicolas
You set a number of "product per slide" to 10, while you have 4 columns and 10 products per page. So that normal that it displays like that. Change the "product per slide" option to 4 and you should have something closer to what we have in the demo website.
14 years 3 months ago #54678 by davemalton
OK it looks more like what you have on your demo site but its not rotating on its own. Attached is another screen shot of what I have the Carosel settings
14 years 3 months ago #54704 by nicolas
That's normal.
You set a number of "product per slide" to 9, while you have 8 columns and 7 products per page.
So that means that on one slide it will display 9 elements and then it will shift 1 product off and on the slide.
But since you're only allowing 7 products in total for the whole slider, it won't display enough products in order to have a slider.
You should follow the settings of the module on the demo website:
The same number for the "number of columns" and the "products per slide" options and a bigger number for the "number of items" option.
That will make it slide.
Also, as in the demo website tutorial, I recommend that you turn on the "slide one by one" option.
14 years 3 months ago #54954 by davemalton
I have tried to duplicate what you have and its still not rotating. File attached
Dave
14 years 3 months ago #54957 by nicolas
Mmm. I don't know how I should explain myself differently. It's the exact same problem as my previous message.
You need to have same number for the "number of columns" and the "products per slide" options and a bigger number for the "number of items" option. That will make it slide.
14 years 3 months ago #54958 by davemalton
ok go look now at what happens new file attached also childrenstoystoystoys.com/
Dave
14 years 3 months ago #54960 by nicolas
It's still not set properly. You have :
number of columns : 7
number of items: 7
products per slide: 12
I keep telling you that the number of items option should have a bigger number than the two others...
It should be:
number of items: 12
products per slide: 7
14 years 3 months ago #54963 by davemalton
Is this correct? if it is still not showing up right. Sorry to be a bother :(
Dave
14 years 3 months ago #54965 by nicolas
Yes, it's good now.
You just need to remove the CSS:
.art-blockcontent-body ul li { line-height: 125%; color: #121517; margin: 5px 0 0 10px; padding: 0 0 0 13px; background-image: url('../images/blockcontentbullets.png'); background-repeat: no-repeat; background-position: top left; }
from childrenstoystoystoys.com/templates/chil...oys/css/template.css and clear your browser's cache.
Your template CSS is interfering with the display of the carousel...
14 years 3 months ago #54967 by davemalton
Well it works in Firefox but not Internet Explorer 9
Dave
14 years 3 months ago #54969 by nicolas
That's caused by a javascript error coming, again, from your template...
Please install and publish the "jquery easy" plugin for joomla and that should fix the problem in IE.
14 years 3 months ago #54982 by davemalton
Thanks thats fixed, should I submit my next problem here or start a new thread? I have items showing up twice on a page. A category of items in boxes on top and then without being boxed on the bottom. And if I click on an item it will show other items on top and I have to scroll down the page to see the item I want to see. See this link for what I mean childrenstoystoystoys.com/index.php/all-...huggington-wr-trains
Dave
14 years 3 months ago #54985 by nicolas
That's because you have created the product listing module at the top and made it display there... Disable it and it won't show. It's the module with the id 43
11 years 1 week ago #216847 by withram
Replied by withram on topic Re: carousel Module?
Hello! I have the same problem with Hikashop 2.6.0. There is no "Number of items" option, so number of items always is the number of columns. If I set 2 cols, I have 2 products in module. If I then set 1 product per slide, I have these two products on two slides with a blank position: joxi.ru/82Qp4qPSeLqZmd . If I choose 3 columns, there will be 3 products in module, but not more.
Unfortunately I can't give you a livesite link, cause it's on localhost now.
11 years 5 days ago #217018 by withram
Anybody here? We need help!
11 years 5 days ago #217029 by Xavier
Replied by Xavier on topic Re: carousel Module?
Please give us more informations about your Joomla version, and screenshots of the page with the issue.
11 years 3 days ago #217196 by withram
Time to create page: 0.265 seconds
