How to Display Products Horizontally
14 years 2 months ago #56985 by carlj315
Simple question. With the JA_Purity template the products are displayed horizontally.
With my own template the products are displayed vertically.
Horizontal looks better! How can I do that?
Is it a template thing? I set the rows to 3 in Configuration/Display but to no success.
14 years 2 months ago #57034 by nicolas
It's just a matter of configuration.
In the hikashop options of your menus/modules you have the same "number of columns" option.
You need to go in each products listing menu/module via the menu Display->Content menus/modules and set the number of columns your want.
14 years 2 months ago #57477 by carlj315
Thanks but I tried that already.
Not working
14 years 2 months ago #57525 by nicolas
That's not possible.
You are not editing the options of the correct menu/module. Please check all of them via the menu Display->Content menus/modules
Time to create page: 0.179 seconds
