how to create filters with products...
14 years 2 months ago #58467 by bluewave
I am running into a situation for how to create this....
I am building a website for loose diamonds. I have created the category, and the sub-categories based on size. However, I need to add color, clarity, and cut to each product. THEN, i would like to be able to create a filter module that I can place on the left hand side (cursor) and allow customers to be able to sort by color, clairty, cut.
IN addition, I would like to be able to sort by price. (Note: I have coded out the filters that occur at the top of the products listing already).
Thanks,
S
14 years 2 months ago #58516 by nicolas
You can create custom fields of the table "product" via Display->Custom fields in order to select/enter the color/clarity/cut information for each product.
Then, you can create filters on these fields via the menu Display->Filters. You can also have a sorting filter on the price by creating one there.
This will require the Business edition of HikaShop.
14 years 2 months ago #58556 by bluewave
THanks.
Yes, I have the business edition. I think I get it. I have something working. Hopefully tonight I can master it and figure out exactly how its all working. I'm rereading the support doc's again for these areas and hopefully tie it all together tonight.
14 years 2 months ago - 14 years 2 months ago #58566 by bluewave
Ok, so i think i am getting close. I created custom field. Then a filter. Then I go to the product and to bottom of the back-end product page and see the custom field with selections. HOWEVER, only one custom field is showing up (clarity). The others are not showing up (cut and color). ????
Last edit: 14 years 2 months ago by bluewave.
14 years 2 months ago #58635 by nicolas
Can you do a screenshot of the options screen of your custom fields so that we can see how you configured them ?
There must be a problem in their configuration.
14 years 2 months ago #58714 by bluewave
I have attached three screenshots. First one is the options for "color" which is not appearing in the product page. The second is for "clarity" which is working well and appearing on product page. And third is the bottom of the product page where the selection can be made on back-end for each product.
14 years 2 months ago #58715 by bluewave
the field for "cut" is also not showing up. I have attached a picture for this also (just like color that doesnt show).
14 years 2 months ago - 14 years 2 months ago #58718 by bluewave
14 years 2 months ago #58770 by nicolas
In your custom fields, please set the option "display limited to" to "all" and then try again.
14 years 2 months ago - 14 years 2 months ago #59002 by bluewave
whoops. nevermind.
ok, got everything working. very well put together system. ! thanks for help!
I just needed to do a few things, including designate a pixel size other than 0 , also.
14 years 2 weeks ago #66099 by plumbingdeals
bluewave...
if i may ask, what is the url for your site.
i need to do filters very similar to what you describe, and would like to see a site with multiple filters.
thank you,
plumbingdeals
14 years 2 weeks ago #66102 by bluewave
plumbingdeals,
my site is currently still under construction and private. I should have it up and publicly available in about 1 to 2 weeks...
Time to create page: 0.288 seconds
