content modules - carousel problem
14 years 2 months ago #59509 by nicolas
That comes from your template's CSS.
You have that CSS in your template:
ul ul {
margin-left: 25px;
padding: 5px 0;
That forces the margin of the uls of the carousel and makes it go on two lines.
Either remove it from your template's CSS, or override it like with some additional CSS:
ul ul {
margin-left: 0px !important;
And that will solve the problem.
14 years 2 months ago #59644 by iloveshop123@gmail.com
Thank you for finding that out.
Would you know which CSS file, that I need to edit?
14 years 2 months ago #59689 by nicolas
No. The CSS is compressed by your template. So it's impossible to know from which file that comes.
However, you could add the override code in the front end CSS of HikaShop via the Display tab of the configuration.
That should work too.
14 years 1 month ago #60174 by iloveshop123@gmail.com
Thank you. I have try to add the override code via the Display tab.
However, any suggestion which front-end CSS of Hikashop should I add to?
And where about with the CSS should I paste that override code.
14 years 1 month ago #60235 by nicolas
You can just click on the edit button of the front end CSS option. There is no need to change the selection.
You can add your CSS at the beginning or at the end of the file.
14 years 1 month ago #60242 by iloveshop123@gmail.com
thank you thank you.
You guys are great.
Time to create page: 0.218 seconds
