Shipping Problem
- condorazul
14 years 1 month ago #62825
by condorazul
Shipping Problem was created by condorazul
I configurated a manual shipping, inside it i created 4 categories, 1 minimun weight 1,5 max weight 9,99 and so on, last one is 20 kg to infinite. I also put the weight in each product to be 1,5 kg. The problem is that only takes the first one in shipping method.
- Thank you received: 1778
14 years 1 month ago #62843
by Mohamed Thelji
Replied by Mohamed Thelji on topic Re: Shipping Problem
Can you please show me screenshots of your shipping methods configuration ?
- condorazul
14 years 1 month ago #62872
by condorazul
Replied by condorazul on topic Re: Shipping Problem
here you are
14 years 1 month ago #63023
Replied by nicolas on topic Re: Shipping Problem
Can you check that the main weight unit (the first one of the list) in your configuration is kg and that you use kg for your products weights.
Can you also try to unpublish the first shipping method and tell us the error you have on the checkout at that point ?
- condorazul
14 years 1 month ago - 14 years 1 month ago #63163
by condorazul
if i unpublish the first one it takes as default the second one, the other problem i see is taht if i change quantity in order i the checkout, no shipping price displays and it dissapers so it is not charged it doesnt update and doesnt select the right one. It doesn´t work anyway
Last edit: 14 years 1 month ago by condorazul.
14 years 1 month ago #63382
Mmm.
Can you check that the auto select default methods option of the configuration of HikaShop is turned on ?
From what you're saying it sounds that you turn off that option.
- condorazul
14 years 1 month ago #63388
by condorazul
it is turned on. And as i tell you the other problem i have is that if in the checkout you change the quantity and refresh shipping price dissapears and it is not added to final price
- condorazul
14 years 1 month ago #63390
by condorazul
I activate and re-adtivate it and it seems it works but i continue having the problem with the refresh option in checkout if you change quantity shipping is not showing and it is not paid
14 years 1 month ago #63544
Can you give a link to that shop so that we can see that ?
- condorazul
14 years 1 month ago #63568
by condorazul
Of course
www.evinar.es
14 years 1 month ago #63877
That's because you don't have the "shipping" view in the "checkout workflow" option of the configuration.
Please add it there and it will work.
If you don't want the shipping selection to be displayed, you can just hide it with CSS, but it has to be there if you want the shipping price to be in the cart.
Time to create page: 0.239 seconds
