Generating products question
13 years 11 months ago #68639 by dunxmax
I have been dabbling with Hikashop for a few months now, and am currently producing a website using Hikashop.
I have a list of 8000+ products that I have imported from a CSV file.
I also have an images folder which relate to the products in the CSV file.
Is it possible to link the imported products from the CSV file with the images folder?
If the answer to the above question is yes, I would like to understand how this happens.
Do the images need to have a reference to the product it relates to?
And secondly, I've already uploaded the products from the CSV file, can I still link the images folder to the products even after the CSV file has been uploaded?
- sorry for these questions, but I didn't quite understand the documentation on this subject.
Incidentally, I know I need to have the business version to actually generate the products. I don't currently have the business version, but I truly am a fan of Hikashop and am definitely prepared to upgrade if linking CSV and images is fairly straightforward.
Thanks for your time.
Dunmax
DunxMax
The more we learn the less we know.
13 years 11 months ago #68806 by nicolas
It's really easy.
Make sure that your images are in the folder media/com_hikashop/upload
Then, in your CSV just enter their filename and they will be linked to the products.
The CSV would look like that if you just want to update existing products:
product_code,images
13 years 11 months ago #69305 by dunxmax
Thanks Nicolas,
This makes sense now.
I can only use this with business version though - is that correct?
Dunxmax
DunxMax
13 years 11 months ago #69472 by nicolas
That can be done in all the editions of HikaShop
Time to create page: 0.201 seconds
