Use external script to add a product to cart
13 years 11 months ago #69517 by momentis
I have a potential new client I am looking to secure a web redevelopment project for. Their existing website (in ASP.NET) has a "store" which allows their site visitors to select items into a "cart" and submit that cart in order to receive a quote. I can do this with HikaShop. However, they also have a "configurator" that allows their visitors to create a custom product and product code, which can also be added to their "cart". The code for this configurator is written in JS, and I believe I can integrate it into a Joomla website. Once a product is configured, there would be a link to add the custom product and code to the shopping cart. Is there a way I could utilize HikaShop for this cart, assuming I will also need to pass custom products and codes into that cart from the configurator?
The following user(s) said Thank You: Rixters
13 years 11 months ago #69727 by nicolas
What I would do in your case is to create a dummy product with custom item fields. Then you can redirect the user to an add to cart url to add the dummy product in the cart with all the custom item fields filled by the parameters of the URL:
www.hikashop.com/en/forum/2-general-talk...-product-fields.html
If you need to also pass the price of the product, then I would recommend to use the donation plugin in order to set the price based on an "amount" custom item field:
demo.hikashop.com/index.php?option=com_h...show&cid=214&lang=en
The following user(s) said Thank You: momentis
13 years 11 months ago #69826 by momentis
That is awesome, Nicolas. That will be PERFECT!!!!!
Thanks!
Time to create page: 0.171 seconds
