Using description in productlist ?
13 years 11 months ago - 13 years 11 months ago #75263 by Supah
Is is possible to add the description of the product in the listing ?
I would like to use the description here:
website
Last edit: 13 years 11 months ago by Supah.
13 years 11 months ago #75286 by Mohamed Thelji
I think that you'll find your answer there :
The simplest option is to change the item box layout option of the module with the id 129 via the menu Display->Content modules to "image and description".
However, that will also change the layout of each item a bit.
If you don't want to change the layout, you can edit the file "listing_img_title" of the view "product" via the menu Display->Views and just add a line of code to display the description:
<?php echo $this->row->product_description; ?>
Hope this will help you.
13 years 11 months ago #75292 by Supah
my display on the menu is by table, do i need to edit listing_table.php then ?
13 years 11 months ago #75297 by Mohamed Thelji
13 years 11 months ago #75311 by Supah
i must be doing something wrong... cause nothing happens :(
i added:
<td class="hikashop_product_code_row">
</td>
13 years 11 months ago #75315 by Mohamed Thelji
you should use this code after these lines :
<?php foreach($this->rows as $row){
13 years 11 months ago #75328 by Supah
are we talking about the same file ?
<?php /** * @package HikaShop for Joomla! * @version 2.0.0 * @author hikashop.com * @copyright (C) 2010-2012 HIKARI SOFTWARE. All rights reserved. * @license GNU/GPLv3 http://www.gnu.org/licenses/gpl-3.0.html */ defined('_JEXEC') or die('Restricted access'); ?><?php if(!empty($this->rows)){ $pagination = $this->config->get('pagination','bottom'); if(in_array($pagination,array('top','both')) && $this->params->get('show_limit') && $this->pageInfo->elements->total >$this->pageInfo->limit->value){ $this->pagination->form = '_top'; ?> <form action="<?php echo hikashop_currentURL(); ?>" method="post" name="adminForm_<?php echo $this->params->get('main_div_name').$this->category_selected;?>_top"> <div class="hikashop_products_pagination hikashop_products_pagination_top"> <?php echo $this->pagination->getListFooter($this->params->get('limit')); ?> <span class="hikashop_results_counter"><?php echo $this->pagination->getResultsCounter(); ?></span> </div> <input type="hidden" name="filter_order_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->value; ?>" /> <input type="hidden" name="filter_order_Dir_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->dir; ?>" /> <?php echo JHTML::_( 'form.token' ); ?> </form> <?php } ?> <div class="hikashop_products"> <?php if ($this->config->get('show_quantity_field')>=2) { ?> <form action="<?php echo hikashop_completeLink('product&task=updatecart'); ?>" method="post" name="hikashop_product_form_<?php echo $this->params->get('main_div_name'); ?>" enctype="multipart/form-data"> <?php } $columns = 1; ?> <table class="hikashop_products_table adminlist table table-striped table-hover" cellpadding="1"> <thead> <tr> <?php if($this->config->get('thumbnail')){ $columns++; ?> <th class="hikashop_product_image title" align="center"> <?php echo JText::_( 'HIKA_IMAGE' );?> </th> <?php } ?> <th class="hikashop_product_name title" align="center"> <?php echo JText::_( 'PRODUCT' );?> </th> <?php if ($this->config->get('show_code')) { $columns++;?> <th class="hikashop_product_code_title" align="center"> <?php echo JText::_( 'PRODUCT_CODE' ); ?> </th> <?php } ?> <?php if($this->params->get('show_vote_product')){ ?> <th class="hikashop_product_price title" align="center"> <?php echo JText::_('VOTE'); ?> </th> <?php } ?> <?php if($this->params->get('show_price','-1')=='-1'){ $config =& hikashop_config(); $this->params->set('show_price',$config->get('show_price')); } if($this->params->get('show_price')){ $columns++; ?> <th class="hikashop_product_price title" align="center"> <?php echo JText::_('PRICE'); ?> </th> <?php } ?> <?php if($this->params->get('add_to_cart') || $this->params->get('add_to_wishlist')){ $columns++; ?> <th class="hikashop_product_add_to_cart title" align="center"> </th> <?php } ?> <?php if(JRequest::getVar('hikashop_front_end_main',0) && JRequest::getVar('task')=='listing' && $this->params->get('show_compare')) { $columns++; ?> <th class="hikashop_product_compare title" align="center"> </th> <?php } ?> </tr> </thead> <tfoot> <tr> <td colspan="<?php echo $columns; ?>"> </td> </tr> </tfoot> <tbody> <?php foreach($this->rows as $row){ $this->row =& $row; $height = $this->params->get('image_height'); $width = $this->params->get('image_width'); if(empty($height)) $height=$this->config->get('thumbnail_y'); if(empty($width)) $width=$this->config->get('thumbnail_x'); $divWidth=$width; $divHeight=$height; $this->image->checkSize($divWidth,$divHeight,$row); $link = hikashop_completeLink('product&task=show&cid='.$this->row->product_id.'&name='.$this->row->alias.$this->itemid.$this->category_pathway); ?> <tr> <?php if($this->config->get('thumbnail')){ ?> <td class="hikashop_product_image_row"> <div style="height:<?php echo $divHeight;?>px;text-align:center;clear:both;" class="hikashop_product_image"> <div style="position:relative;text-align:center;clear:both;width:<?php echo $divWidth;?>px;margin: auto;" class="hikashop_product_image_subdiv"> <?php if($this->params->get('link_to_product_page',1)){ ?> <a href="<?php echo $link;?>" title="<?php echo $this->escape($this->row->product_name); ?>"> <?php } echo $this->image->display(@$this->row->file_path,false,$this->escape($this->row->file_name),"","", $width ,$height); $main_thumb_x = $this->image->main_thumbnail_x; $main_thumb_y = $this->image->main_thumbnail_y; $this->classbadge->placeBadges($this->image, $this->row->badges, -10, 0); $this->image->main_thumbnail_x = $main_thumb_x; $this->image->main_thumbnail_y = $main_thumb_y; if($this->params->get('link_to_product_page',1)){ ?> </a> <?php } ?> </div> </div> </td> <?php } ?> <td class="hikashop_product_name_row"> <span class="hikashop_product_name"> <?php if($this->params->get('link_to_product_page',1)){ ?> <a href="<?php echo $link;?>"> <?php } echo $this->row->product_name; if($this->params->get('link_to_product_page',1)){ ?> </a> <?php } ?> </span> </td> <?php if ($this->config->get('show_code')){ ?> <td class="hikashop_product_code_row"> <?php echo $this->row->product_code; ?> </td> [b] <td class="hikashop_product_code_row"> <?php echo $this->row->product_description; ?> </td>[/b] <?php } ?> <?php if($this->params->get('show_vote_product')){ ?> <td class="hikashop_product_vote_row"> <?php $this->row =& $row; $this->setLayout('listing_vote'); echo $this->loadTemplate(); ?> </td> <?php } ?> <?php if($this->params->get('show_price','-1')=='-1'){ $config =& hikashop_config(); $this->params->set('show_price',$config->get('show_price')); } if($this->params->get('show_price')){ ?> <td class="hikashop_product_price_row"> <?php $this->setLayout('listing_price'); echo $this->loadTemplate(); ?> </td> <?php } ?> <?php if($this->params->get('add_to_cart')){ ?> <td class="hikashop_product_add_to_cart_row"> <?php $this->setLayout('add_to_cart_listing'); echo $this->loadTemplate(); ?> </td> <?php } ?> <?php if(JRequest::getVar('hikashop_front_end_main',0) && JRequest::getVar('task')=='listing' && $this->params->get('show_compare')) { if( $this->params->get('show_compare') == 1 ) { ?> <td class="hikashop_product_compare_row"> <a class="hikashop_compare_button" href="<?php echo $link;?>" onclick="setToCompareList(<?php echo $this->row->product_id;?>,'<?php echo $this->escape($this->row->product_name); ?>',this); return false;"><?php echo JText::_('ADD_TO_COMPARE_LIST'); ?></a> </td> <?php } else { ?> <td class="hikashop_product_compare_row"> <input type="checkbox" class="hikashop_compare_checkbox" id="hikashop_listing_chk_<?php echo $this->row->product_id;?>" onchange="setToCompareList(<?php echo $this->row->product_id;?>,'<?php echo $this->escape($this->row->product_name); ?>',this);"><label for="hikashop_listing_chk_<?php echo $this->row->product_id;?>"><?php echo JText::_('ADD_TO_COMPARE_LIST'); ?></label> </td> <?php } } ?> </tr> <?php } ?> </tbody> </table> <?php if ($this->config->get('show_quantity_field')>=2) { $this->ajax = 'if(hikashopCheckChangeForm(\'item\',\'hikashop_product_form_'.$this->params->get('main_div_name').'\')){ return hikashopModifyQuantity(\'\',field,1,\'hikashop_product_form_'.$this->params->get('main_div_name').'\'); } return false;'; $this->row = null; $this->row->product_quantity = -1; $this->row->product_min_per_order = 0; $this->row->product_max_per_order = -1; $this->row->product_sale_start = 0; $this->row->product_sale_end = 0; $this->setLayout('quantity'); echo $this->loadTemplate(); if(!empty($this->ajax) && $this->config->get('redirect_url_after_add_cart','stay_if_cart')=='ask_user'){ ?> <input type="hidden" name="popup" value="1"/> <?php } ?> <input type="hidden" name="hikashop_cart_type_0" id="hikashop_cart_type_0" value="cart"/> <input type="hidden" name="add" value="1"/> <input type="hidden" name="ctrl" value="product"/> <input type="hidden" name="task" value="updatecart"/> <input type="hidden" name="return_url" value="<?php echo urlencode(base64_encode(urldecode($this->redirect_url)));?>"/> </form> <?php } if(in_array($pagination,array('bottom','both')) && $this->params->get('show_limit') && $this->pageInfo->elements->total > $this->pageInfo->limit->value){ $this->pagination->form = '_bottom'; ?> <form action="<?php echo hikashop_currentURL(); ?>" method="post" name="adminForm_<?php echo $this->params->get('main_div_name').$this->category_selected;?>_bottom"> <div class="hikashop_products_pagination hikashop_products_pagination_bottom"> <?php echo $this->pagination->getListFooter(); ?> <span class="hikashop_results_counter"><?php echo $this->pagination->getResultsCounter(); ?></span> </div> <input type="hidden" name="filter_order_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->value; ?>" /> <input type="hidden" name="filter_order_Dir_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->dir; ?>" /> <?php echo JHTML::_( 'form.token' ); ?> </form> <?php } ?> </div> <?php } ?>
13 years 11 months ago #75332 by nicolas
You added your code inside that:
That means that the description will only display if you turn on the display of the product code.
Try to add it just before that.
Also, make sure that you're editing that file for your frontend template.
13 years 11 months ago - 13 years 11 months ago #75391 by Supah
nicolas wrote: You added your code inside that:
im sorry i don't get that...
i added this:
thats all i added to active template listing_table.php
13 years 11 months ago #75402 by Supah
i'm sorry !
had to read it a few times more before i got it ;)
thanks !
11 years 10 months ago #184460 by naranjacuatro
hello,
I'm trying to do the same but there must me something wrong... :-/
do I have to edit listing_table.php or product/listing_img_title.php?
the code I´m adding is:
</td>
11 years 10 months ago #184464 by nicolas
It depends how you configured your products listing. If you configured it to display as a table, then you want to modify listing_table.
If you configured it to display with DIVs, then it's the listing_img_title file that you want to edit.
11 years 10 months ago - 11 years 10 months ago #184499 by naranjacuatro
hi there,
yes, I configured it as a table... and modified product/listing_table.php but still not working... could you have a look please? :blush:
<?php /** * @package HikaShop for Joomla! * @version 2.2.2 * @author hikashop.com * @copyright (C) 2010-2013 HIKARI SOFTWARE. All rights reserved. * @license GNU/GPLv3 http://www.gnu.org/licenses/gpl-3.0.html */ defined('_JEXEC') or die('Restricted access'); ?><?php if(!empty($this->rows)){ $pagination = $this->config->get('pagination','bottom'); if(in_array($pagination,array('top','both')) && $this->params->get('show_limit') && $this->pageInfo->elements->total){ $this->pagination->form = '_top'; ?> <form action="<?php echo hikashop_currentURL(); ?>" method="post" name="adminForm_<?php echo $this->params->get('main_div_name').$this->category_selected;?>_top"> <div class="hikashop_products_pagination hikashop_products_pagination_top"> <?php echo $this->pagination->getListFooter($this->params->get('limit')); ?> <span class="hikashop_results_counter"><?php echo $this->pagination->getResultsCounter(); ?></span> </div> <input type="hidden" name="filter_order_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->value; ?>" /> <input type="hidden" name="filter_order_Dir_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->dir; ?>" /> <?php echo JHTML::_( 'form.token' ); ?> </form> <?php } ?> <div class="hikashop_products"> <?php if ($this->config->get('show_quantity_field')>=2) { ?> <form action="<?php echo hikashop_completeLink('product&task=updatecart'); ?>" method="post" name="hikashop_product_form_<?php echo $this->params->get('main_div_name'); ?>" enctype="multipart/form-data"> <?php } $columns = 1; ?> <table class="hikashop_products_table adminlist table table-striped table-hover" cellpadding="1"> <thead> <tr> <?php if($this->config->get('thumbnail')){ $columns++; ?> <th class="hikashop_product_image title" align="center"> <?php echo JText::_( 'HIKA_IMAGE' );?> </th> <?php } ?> <th class="hikashop_product_name title" align="center"> <?php echo JText::_( 'PRODUCT' );?> </th> <?php if ($this->config->get('show_code')) { $columns++;?> <th class="hikashop_product_code_title" align="center"> <?php echo JText::_( 'PRODUCT_CODE' ); ?> <?php echo $this->row->product_description; ?> </th> <?php } ?> <?php if($this->params->get('show_vote_product')){ ?> <th class="hikashop_product_vote title" align="center"> <?php echo JText::_('VOTE'); ?> </th> <th class="hikashop_product_code_row"> <?php echo $this->row->product_description; ?> </th> <?php } ?> <?php if($this->params->get('show_price','-1')=='-1'){ $config =& hikashop_config(); $this->params->set('show_price',$config->get('show_price')); } if($this->params->get('show_price')){ $columns++; ?> <th class="hikashop_product_price title" align="center"> <?php echo JText::_('PRICE'); ?> </th> <?php } ?> <?php if($this->params->get('add_to_cart') || $this->params->get('add_to_wishlist')){ $columns++; ?> <th class="hikashop_product_add_to_cart title" align="center"> </th> <?php } ?> <?php if(JRequest::getVar('hikashop_front_end_main',0) && JRequest::getVar('task')=='listing' && $this->params->get('show_compare')) { $columns++; ?> <th class="hikashop_product_compare title" align="center"> </th> <?php } ?> </tr> </thead> <tfoot> <tr> <td colspan="<?php echo $columns; ?>"> </td> </tr> </tfoot> <tbody> <?php foreach($this->rows as $row){ $this->row =& $row; $height = $this->params->get('image_height'); $width = $this->params->get('image_width'); if(empty($height)) $height=$this->config->get('thumbnail_y'); if(empty($width)) $width=$this->config->get('thumbnail_x'); $divWidth=$width; $divHeight=$height; $this->image->checkSize($divWidth,$divHeight,$row); $link = hikashop_completeLink('product&task=show&cid='.$this->row->product_id.'&name='.$this->row->alias.$this->itemid.$this->category_pathway); ?> <tr> <?php if($this->config->get('thumbnail')){ ?> <td class="hikashop_product_image_row"> <div style="height:<?php echo $divHeight;?>px;text-align:center;clear:both;" class="hikashop_product_image"> <div style="position:relative;text-align:center;clear:both;width:<?php echo $divWidth;?>px;margin: auto;" class="hikashop_product_image_subdiv"> <?php if($this->params->get('link_to_product_page',1)){ ?> <a href="<?php echo $link;?>" title="<?php echo $this->escape($this->row->product_name); ?>"> <?php } echo $this->image->display(@$this->row->file_path,false,$this->escape($this->row->file_name),"","", $width ,$height); $main_thumb_x = $this->image->main_thumbnail_x; $main_thumb_y = $this->image->main_thumbnail_y; if($this->params->get('display_badges',1)){ $this->classbadge->placeBadges($this->image, $this->row->badges, -10, 0); } $this->image->main_thumbnail_x = $main_thumb_x; $this->image->main_thumbnail_y = $main_thumb_y; if($this->params->get('link_to_product_page',1)){ ?> </a> <?php } ?> </div> </div> </td> <?php } ?> <td class="hikashop_product_name_row"> <span class="hikashop_product_name"> <?php if($this->params->get('link_to_product_page',1)){ ?> <a href="<?php echo $link;?>"> <?php } echo $this->row->product_name; if($this->params->get('link_to_product_page',1)){ ?> </a> <?php } ?> </span> <?php if(!empty($this->row->extraData->afterProductName)) { echo implode("\r\n",$this->row->extraData->afterProductName); } ?> </td> <?php if ($this->config->get('show_code')){ ?> <td class="hikashop_product_code_row"> <?php if($this->params->get('link_to_product_page',1)){ ?> <a href="<?php echo $link;?>"> <?php } echo $this->row->product_code; if($this->params->get('link_to_product_page',1)){ ?> </a> <?php } ?> </td> <?php } ?> <?php if($this->params->get('show_vote_product')){ ?> <td class="hikashop_product_vote_row"> <?php $this->row =& $row; $this->setLayout('listing_vote'); echo $this->loadTemplate(); ?> </td> <?php } ?> <?php if($this->params->get('show_price','-1')=='-1'){ $config =& hikashop_config(); $this->params->set('show_price',$config->get('show_price')); } if($this->params->get('show_price')){ ?> <td class="hikashop_product_price_row"> <?php $this->setLayout('listing_price'); echo $this->loadTemplate(); ?> </td> <?php } ?> <?php if($this->params->get('add_to_cart')){ ?> <td class="hikashop_product_add_to_cart_row"> <?php $this->setLayout('add_to_cart_listing'); echo $this->loadTemplate(); ?> </td> <?php } ?> <?php if(JRequest::getVar('hikashop_front_end_main',0) && JRequest::getVar('task')=='listing' && $this->params->get('show_compare')) { if( $this->params->get('show_compare') == 1 ) { ?> <td class="hikashop_product_compare_row"> <a class="hikashop_compare_button" href="<?php echo $link;?>" onclick="setToCompareList(<?php echo $this->row->product_id;?>,'<?php echo $this->escape($this->row->product_name); ?>',this); return false;"><?php echo JText::_('ADD_TO_COMPARE_LIST'); ?></a> </td> <?php } else { ?> <td class="hikashop_product_compare_row"> <input type="checkbox" class="hikashop_compare_checkbox" id="hikashop_listing_chk_<?php echo $this->row->product_id;?>" onchange="setToCompareList(<?php echo $this->row->product_id;?>,'<?php echo $this->escape($this->row->product_name); ?>',this);"><label for="hikashop_listing_chk_<?php echo $this->row->product_id;?>"><?php echo JText::_('ADD_TO_COMPARE_LIST'); ?></label> </td> <?php } } ?> </tr> <?php } ?> </tbody> </table> <?php if ($this->config->get('show_quantity_field')>=2) { $this->ajax = 'if(hikashopCheckChangeForm(\'item\',\'hikashop_product_form_'.$this->params->get('main_div_name').'\')){ return hikashopModifyQuantity(\'\',field,1,\'hikashop_product_form_'.$this->params->get('main_div_name').'\'); } return false;'; $this->row = null; $this->row->product_quantity = -1; $this->row->product_min_per_order = 0; $this->row->product_max_per_order = -1; $this->row->product_sale_start = 0; $this->row->product_sale_end = 0; $this->setLayout('quantity'); echo $this->loadTemplate(); if(!empty($this->ajax) && $this->config->get('redirect_url_after_add_cart','stay_if_cart')=='ask_user'){ ?> <input type="hidden" name="popup" value="1"/> <?php } ?> <input type="hidden" name="hikashop_cart_type_0" id="hikashop_cart_type_0" value="cart"/> <input type="hidden" name="add" value="1"/> <input type="hidden" name="ctrl" value="product"/> <input type="hidden" name="task" value="updatecart"/> <input type="hidden" name="return_url" value="<?php echo urlencode(base64_encode(urldecode($this->redirect_url)));?>"/> </form> <?php } if(in_array($pagination,array('bottom','both')) && $this->params->get('show_limit') && $this->pageInfo->elements->total){ $this->pagination->form = '_bottom'; ?> <form action="<?php echo hikashop_currentURL(); ?>" method="post" name="adminForm_<?php echo $this->params->get('main_div_name').$this->category_selected;?>_bottom"> <div class="hikashop_products_pagination hikashop_products_pagination_bottom"> <?php echo $this->pagination->getListFooter($this->params->get('limit')); ?> <span class="hikashop_results_counter"><?php echo $this->pagination->getResultsCounter(); ?></span> </div> <input type="hidden" name="filter_order_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->value; ?>" /> <input type="hidden" name="filter_order_Dir_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->dir; ?>" /> <?php echo JHTML::_( 'form.token' ); ?> </form> <?php } ?> </div> <?php } ?>
Last edit: 11 years 10 months ago by nicolas.
11 years 9 months ago #184503 by nicolas
Make sure that you have the "show product code" option activated in the HikaShop configuration since you replaced the display of the product code by the display of the description.
11 years 9 months ago - 11 years 9 months ago #184547 by naranjacuatro
ok... i see...
as I preffer the short description appears under the title I wrote it here, but... is there any other change that I have to do or just adding this should work? Because I don´t get results yet... :(
<?php /** * @package HikaShop for Joomla! * @version 2.2.2 * @author hikashop.com * @copyright (C) 2010-2013 HIKARI SOFTWARE. All rights reserved. * @license GNU/GPLv3 http://www.gnu.org/licenses/gpl-3.0.html */ defined('_JEXEC') or die('Restricted access'); ?><?php if(!empty($this->rows)){ $pagination = $this->config->get('pagination','bottom'); if(in_array($pagination,array('top','both')) && $this->params->get('show_limit') && $this->pageInfo->elements->total){ $this->pagination->form = '_top'; ?> <form action="<?php echo hikashop_currentURL(); ?>" method="post" name="adminForm_<?php echo $this->params->get('main_div_name').$this->category_selected;?>_top"> <div class="hikashop_products_pagination hikashop_products_pagination_top"> <?php echo $this->pagination->getListFooter($this->params->get('limit')); ?> <span class="hikashop_results_counter"><?php echo $this->pagination->getResultsCounter(); ?></span> </div> <input type="hidden" name="filter_order_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->value; ?>" /> <input type="hidden" name="filter_order_Dir_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->dir; ?>" /> <?php echo JHTML::_( 'form.token' ); ?> </form> <?php } ?> <div class="hikashop_products"> <?php if ($this->config->get('show_quantity_field')>=2) { ?> <form action="<?php echo hikashop_completeLink('product&task=updatecart'); ?>" method="post" name="hikashop_product_form_<?php echo $this->params->get('main_div_name'); ?>" enctype="multipart/form-data"> <?php } $columns = 1; ?> <table class="hikashop_products_table adminlist table table-striped table-hover" cellpadding="1"> <thead> <tr> <?php if($this->config->get('thumbnail')){ $columns++; ?> <th class="hikashop_product_image title" align="center"> <?php echo JText::_( 'HIKA_IMAGE' );?> </th> <?php } ?> <th class="hikashop_product_name title" align="center"> <?php echo JText::_( 'PRODUCT' );?> <?php echo $this->row->product_description; ?> </th> <?php if ($this->config->get('show_code')) { $columns++;?> <th class="hikashop_product_code_title" align="center"> <?php echo JText::_( 'PRODUCT_CODE' ); ?> </th> <?php } ?> <?php if($this->params->get('show_vote_product')){ ?> <th class="hikashop_product_vote title" align="center"> <?php echo JText::_('VOTE'); ?> </th> <?php } ?> <?php if($this->params->get('show_price','-1')=='-1'){ $config =& hikashop_config(); $this->params->set('show_price',$config->get('show_price')); } if($this->params->get('show_price')){ $columns++; ?> <th class="hikashop_product_price title" align="center"> <?php echo JText::_('PRICE'); ?> </th> <?php } ?> <?php if($this->params->get('add_to_cart') || $this->params->get('add_to_wishlist')){ $columns++; ?> <th class="hikashop_product_add_to_cart title" align="center"> </th> <?php } ?> <?php if(JRequest::getVar('hikashop_front_end_main',0) && JRequest::getVar('task')=='listing' && $this->params->get('show_compare')) { $columns++; ?> <th class="hikashop_product_compare title" align="center"> </th> <?php } ?> </tr> </thead> <tfoot> <tr> <td colspan="<?php echo $columns; ?>"> </td> </tr> </tfoot> <tbody> <?php foreach($this->rows as $row){ $this->row =& $row; $height = $this->params->get('image_height'); $width = $this->params->get('image_width'); if(empty($height)) $height=$this->config->get('thumbnail_y'); if(empty($width)) $width=$this->config->get('thumbnail_x'); $divWidth=$width; $divHeight=$height; $this->image->checkSize($divWidth,$divHeight,$row); $link = hikashop_completeLink('product&task=show&cid='.$this->row->product_id.'&name='.$this->row->alias.$this->itemid.$this->category_pathway); ?> <tr> <?php if($this->config->get('thumbnail')){ ?> <td class="hikashop_product_image_row"> <div style="height:<?php echo $divHeight;?>px;text-align:center;clear:both;" class="hikashop_product_image"> <div style="position:relative;text-align:center;clear:both;width:<?php echo $divWidth;?>px;margin: auto;" class="hikashop_product_image_subdiv"> <?php if($this->params->get('link_to_product_page',1)){ ?> <a href="<?php echo $link;?>" title="<?php echo $this->escape($this->row->product_name); ?>"> <?php } echo $this->image->display(@$this->row->file_path,false,$this->escape($this->row->file_name),"","", $width ,$height); $main_thumb_x = $this->image->main_thumbnail_x; $main_thumb_y = $this->image->main_thumbnail_y; if($this->params->get('display_badges',1)){ $this->classbadge->placeBadges($this->image, $this->row->badges, -10, 0); } $this->image->main_thumbnail_x = $main_thumb_x; $this->image->main_thumbnail_y = $main_thumb_y; if($this->params->get('link_to_product_page',1)){ ?> </a> <?php } ?> </div> </div> </td> <?php } ?> <td class="hikashop_product_name_row"> <span class="hikashop_product_name"> <?php if($this->params->get('link_to_product_page',1)){ ?> <a href="<?php echo $link;?>"> <?php } echo $this->row->product_name; if($this->params->get('link_to_product_page',1)){ ?> </a> <?php } ?> </span> <?php if(!empty($this->row->extraData->afterProductName)) { echo implode("\r\n",$this->row->extraData->afterProductName); } ?> </td> <?php if ($this->config->get('show_code')){ ?> <td class="hikashop_product_code_row"> <?php if($this->params->get('link_to_product_page',1)){ ?> <a href="<?php echo $link;?>"> <?php } echo $this->row->product_code; if($this->params->get('link_to_product_page',1)){ ?> </a> <?php } ?> </td> <?php } ?> <?php if($this->params->get('show_vote_product')){ ?> <td class="hikashop_product_vote_row"> <?php $this->row =& $row; $this->setLayout('listing_vote'); echo $this->loadTemplate(); ?> </td> <?php } ?> <?php if($this->params->get('show_price','-1')=='-1'){ $config =& hikashop_config(); $this->params->set('show_price',$config->get('show_price')); } if($this->params->get('show_price')){ ?> <td class="hikashop_product_price_row"> <?php $this->setLayout('listing_price'); echo $this->loadTemplate(); ?> </td> <?php } ?> <?php if($this->params->get('add_to_cart')){ ?> <td class="hikashop_product_add_to_cart_row"> <?php $this->setLayout('add_to_cart_listing'); echo $this->loadTemplate(); ?> </td> <?php } ?> <?php if(JRequest::getVar('hikashop_front_end_main',0) && JRequest::getVar('task')=='listing' && $this->params->get('show_compare')) { if( $this->params->get('show_compare') == 1 ) { ?> <td class="hikashop_product_compare_row"> <a class="hikashop_compare_button" href="<?php echo $link;?>" onclick="setToCompareList(<?php echo $this->row->product_id;?>,'<?php echo $this->escape($this->row->product_name); ?>',this); return false;"><?php echo JText::_('ADD_TO_COMPARE_LIST'); ?></a> </td> <?php } else { ?> <td class="hikashop_product_compare_row"> <input type="checkbox" class="hikashop_compare_checkbox" id="hikashop_listing_chk_<?php echo $this->row->product_id;?>" onchange="setToCompareList(<?php echo $this->row->product_id;?>,'<?php echo $this->escape($this->row->product_name); ?>',this);"><label for="hikashop_listing_chk_<?php echo $this->row->product_id;?>"><?php echo JText::_('ADD_TO_COMPARE_LIST'); ?></label> </td> <?php } } ?> </tr> <?php } ?> </tbody> </table> <?php if ($this->config->get('show_quantity_field')>=2) { $this->ajax = 'if(hikashopCheckChangeForm(\'item\',\'hikashop_product_form_'.$this->params->get('main_div_name').'\')){ return hikashopModifyQuantity(\'\',field,1,\'hikashop_product_form_'.$this->params->get('main_div_name').'\'); } return false;'; $this->row = null; $this->row->product_quantity = -1; $this->row->product_min_per_order = 0; $this->row->product_max_per_order = -1; $this->row->product_sale_start = 0; $this->row->product_sale_end = 0; $this->setLayout('quantity'); echo $this->loadTemplate(); if(!empty($this->ajax) && $this->config->get('redirect_url_after_add_cart','stay_if_cart')=='ask_user'){ ?> <input type="hidden" name="popup" value="1"/> <?php } ?> <input type="hidden" name="hikashop_cart_type_0" id="hikashop_cart_type_0" value="cart"/> <input type="hidden" name="add" value="1"/> <input type="hidden" name="ctrl" value="product"/> <input type="hidden" name="task" value="updatecart"/> <input type="hidden" name="return_url" value="<?php echo urlencode(base64_encode(urldecode($this->redirect_url)));?>"/> </form> <?php } if(in_array($pagination,array('bottom','both')) && $this->params->get('show_limit') && $this->pageInfo->elements->total){ $this->pagination->form = '_bottom'; ?> <form action="<?php echo hikashop_currentURL(); ?>" method="post" name="adminForm_<?php echo $this->params->get('main_div_name').$this->category_selected;?>_bottom"> <div class="hikashop_products_pagination hikashop_products_pagination_bottom"> <?php echo $this->pagination->getListFooter($this->params->get('limit')); ?> <span class="hikashop_results_counter"><?php echo $this->pagination->getResultsCounter(); ?></span> </div> <input type="hidden" name="filter_order_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->value; ?>" /> <input type="hidden" name="filter_order_Dir_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->dir; ?>" /> <?php echo JHTML::_( 'form.token' ); ?> </form> <?php } ?> </div> <?php } ?>
Last edit: 11 years 9 months ago by nicolas.
11 years 9 months ago #184579 by nicolas
You added it below the product title.
That's not possible to do that.
In that case, you want to add it before the line:
11 years 9 months ago #184632 by naranjacuatro
I can´t find that line in my product / listing_table.php O_O
11 years 9 months ago #184681 by lousyfool
It's there. Look around line 149.
The following user(s) said Thank You: naranjacuatro
11 years 9 months ago #184827 by naranjacuatro
at least!
now its works!! thank you very very much! ^_^
one last thing... any way to show title in bold? :P
11 years 9 months ago #184829 by lousyfool
naranjacuatro wrote: any way to show title in bold?
Sure, just add some custom CSS: www.hikashop.com/support/support/documen...the-display.html#css
For example:
.hikashop_product_name a { font-weight: bold; }
Time to create page: 0.673 seconds
