view cart button on a mini cart module
13 years 10 months ago #83316 by mirlinda.kosova
Hi guys!
I would like to put on my hikashop minicart a button "view cart" which would open some kind of popup. In the popup there would be the whole cart content displayed. Here is a similar case to what I am aiming to:
demo.smartaddons.com/#sj-minicart-pro
Will you please help me how to do that? Waiting for your reply. Thanks in advance.
13 years 10 months ago #83416 by mirlinda.kosova
Still waiting for reply. Hope to get help from you soon....
13 years 10 months ago #83568 by Jerome
The HikaShop team wish you happy holidays - The support will be delayed until January. Thank you for bearing with us in the mean time..
You have to edit the "product | cart" view and add a popup button which would point to: hikashop_completeLink('cart', true) (which would be: "index.php?option=com_hikashop&ctrl=cart&tmpl=component").
13 years 10 months ago #83651 by mirlinda.kosova
I couldn't get it work so would you please check the code. I am guessing that my mistake is on the link?:
<script type="text/javascript">
// Popup window code
function newPopup(url) {
popupWindow = window.open(
url,'popUpWindow','height=200,width=300,left=10,top=10,resizable=yes,scrollbars=yes,toolbar=yes,menubar=no,location=no,directories=no,status=yes')
</script>
<a href="JavaScript:newPopup('hikashop_index.php?option=com_hikashop&ctrl=cart&tmpl=component('cart', true)');">View cart</a>
Thanks a lot!
13 years 9 months ago #83950 by mirlinda.kosova
Still waiting for your help. Thanks!
13 years 9 months ago #84155 by mirlinda.kosova
I also tried to get it work first as a simple link by using on the view "product | cart" this next code:
<a href="<?php echo hikashop_completeLink('cart',true);?>" >View cart</a>
but when I open View cart link it shows me source code of the page. This is the outcome smartshop-ks.com/jo/index.php/bukuri/cart/tmpl-component
Will you please help me with this since I've tried everything and I can't get it work. Here is my website smartshop-ks.com/jo/
As I pointed on the message above I am trying to get something like this demo.smartaddons.com/#sj-minicart-pro --> when you add a product to your cart you can then view the cart by pointing your cart text.
Hope to hear from you soon.
13 years 9 months ago #84241 by nicolas
Note that each time you reply, it goes back at the top of the queue in our ticket system, so you actually have to wait longer for our reply.
I think that the code should be like that:
</script>
<a href="JavaScript:newPopup('<?php echo hikashop_completeLink('cart',true);?>');">View cart</a>
Did you try like that ? Does it work ? If you still have the same issue with the code of the cart being displayed instead of the cart itself in the popup, I would recommend to make sure that your template's component.php file is not the one adding the pre html tags around the html of the cart.
13 years 9 months ago #84256 by mirlinda.kosova
Thanks a lot for your help but it still isn't working. I tried to look what can I do on my template's component.php file but could not figure out what to do so that it would not add the pre html tags around the html of the cart.
Did you have any similar case before and solve it? Would you please share the ticket link if that is the case?
Here is my template's component.php code:
<?php
* @package Joomla.Site
* @subpackage Templates.beez_20
* @copyright Copyright (C) 2005 - 2012 Open Source Matters, Inc. All rights reserved.
* @license GNU General Public License version 2 or later; see LICENSE.txt
// No direct access.
defined('_JEXEC') or die;
$doc = JFactory::getDocument();
$color = $this->params->get('templatecolor');
$doc->addStyleSheet($this->baseurl.'/templates/system/css/system.css');
$doc->addStyleSheet($this->baseurl.'/templates/'.$this->template.'/css/template.css', $type = 'text/css', $media = 'screen,projection');
$doc->addStyleSheet($this->baseurl.'/templates/'.$this->template.'/css/position.css', $type = 'text/css', $media = 'screen,projection');
$doc->addStyleSheet($this->baseurl.'/templates/'.$this->template.'/css/layout.css', $type = 'text/css', $media = 'screen,projection');
$doc->addStyleSheet($this->baseurl.'/templates/'.$this->template.'/css/print.css', $type = 'text/css', $media = 'print');
$files = JHtml::_('stylesheet', 'templates/'.$this->template.'/css/general.css', null, false, true);
if ($files):
if (!is_array($files)):
$files = array($files);
endif;
foreach($files as $file):
$doc->addStyleSheet($file);
endforeach;
endif;
$doc->addStyleSheet('templates/'.$this->template.'/css/'.htmlspecialchars($color).'.css');
if ($this->direction == 'rtl') {
$doc->addStyleSheet($this->baseurl.'/templates/'.$this->template.'/css/template_rtl.css');
if (file_exists(JPATH_SITE . '/templates/' . $this->template . '/css/' . $color . '_rtl.css')) {
$doc->addStyleSheet($this->baseurl.'/templates/'.$this->template.'/css/'.htmlspecialchars($color).'_rtl.css');
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" " www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd ">
<html xmlns=" www.w3.org/1999/xhtml " xml:lang="<?php echo $this->language; ?>" lang="<?php echo $this->language; ?>" dir="<?php echo $this->direction; ?>">
<head>
<jdoc:include type="head" />
<!--[if lte IE 6]>
<link href="<?php echo $this->baseurl ?>/templates/<?php echo $this->template; ?>/css/ieonly.css" rel="stylesheet" type="text/css" />
<![endif]-->
</head>
<body class="contentpane">
<div id="all">
<div id="main">
<jdoc:include type="message" />
<jdoc:include type="component" />
</div>
</div>
</body>
</html>
I didn't until now had this kind of problem with this template and other components.
/Mirlinda
13 years 9 months ago #85186 by nicolas
I checked the code of the component.php file of your template but it's fine.
I must come from something else on your website then.
I've never seen such issue so I can only guess that it comes from a very specific extension on your website which not a lot of people uses.
13 years 9 months ago #85251 by mirlinda.kosova
Thank you for your replay.
I'll try to deactivate my extensions one by one and see if it works. I have only few extensions and they are very common ones so I am still wondering why is this problem only with Hikashop. Will you please let me know if you find any solution for this as this is quite important part of my website.
/Mirlinda
13 years 6 months ago #98032 by mirlinda.kosova
Hello!
I am still having the same problem even when deactivating most of others modules or plugins.
Do you have any alternative solution for me to get it work the way I wanted?
13 years 6 months ago #98033 by mirlinda.kosova
I was wondering why link hikashop_completeLink('checkout',true); is working without any problem. When I add this to "product | cart" view it is working perfectly:
<a title="<?php echo JText::_('HIKA_PRINT');?>" class="modal" rel="{handler: 'iframe', size: {x: 760, y: 480}}" href="<?php echo hikashop_completeLink('checkout',true); ?>"> Testing </a>
as soon as I change link to href="<?php echo hikashop_completeLink('cart',true); ?>"> it is only showing source code of the view.
So if the problem as suspected would be in any module than I would have the same problem with checkout view as well.
13 years 6 months ago #98045 by mirlinda.kosova
I also tried:
<a title="<?php echo JText::_('SHOW_CART');?>" class="modal" rel="{handler: 'iframe', size: {x: 760, y: 480}}" href="<?php echo hikashop_completeLink('cart&task=showcart',true); ?>">
Show Cart
</a>
this is working BUT after it opens the modal window with the cart on it, it also opens printing window. I don't want printing window to be showed to the customer.
13 years 6 months ago #98046 by mirlinda.kosova
Is there maybe something wrong with my product / cart.php view? Will you please check out the code?
<?php
* @version 2.0.0
* @author hikashop.com
?><?php
global $Itemid;
$Itemid = '&Itemid='.$Itemid;
$this->params->set('show_quantity_field', 0);
$desc = $this->params->get('msg');
$cart_type = $this->params->get('cart_type','cart');
if($cart_type == 'wishlist'){
$convertText = JText::_('WISHLIST_TO_CART');
$displayText = JText::_('DISPLAY_THE_WISHLIST');
$displayAllText = JText::_('DISPLAY_THE_WISHLISTS');
$emptyText = JText::_('WISHLIST_EMPTY');
}else{
$convertText = JText::_('CART_TO_WISHLIST');
$displayText = JText::_('DISPLAY_THE_CART');
$displayAllText = JText::_('DISPLAY_THE_CARTS');
$emptyText = JText::_('CART_EMPTY');
if(empty($desc) && $desc != '0'){
$this->params->set('msg',$emptyText);
if(!headers_sent()){
header( 'Cache-Control: no-store, no-cache, must-revalidate' );
header( 'Cache-Control: post-check=0, pre-check=0', false );
header( 'Pragma: no-cache' );
$cart_type=$this->params->get('cart_type','cart');
if($this->params->get('from','no') == 'no'){
$this->params->set('from',JRequest::getString('from','display'));
if(empty($this->rows)){
$desc = trim($this->params->get('msg'));
if(!empty($desc) || $desc == '0'){
echo $this->notice_html; ?>
<div id="hikashop_cart" class="hikashop_cart">
<?php echo $desc; ?>
</div>
<div class="clear_both"></div>
<?php
}else{ ?>
<?php
if($this->config->get('print_cart',0) && JRequest::getVar('tmpl','')!='component' && $cart_type != 'wishlist'){ ?>
<div class="hikashop_checkout_cart_print_link">
<a title="<?php echo JText::_('HIKA_PRINT');?>" class="modal" rel="{handler: 'iframe', size: {x: 760, y: 480}}" href="<?php echo hikashop_completeLink('checkout&task=printcart',true); ?>">
<img src="<?php echo HIKASHOP_IMAGES; ?>print.png" alt="<?php echo JText::_('HIKA_PRINT');?>"/>
</a>
</div>
<?php
else if($this->params->get('from','display') != 'module'){
echo '<div class="hikashop_product_cart_links">';
echo '<div class="hikashop_product_cart_show_carts_link">';
echo $this->cart->displayButton($displayAllText,'cart',$this->params,hikashop_completeLink('cart&task=showcarts&cart_type='.$cart_type.$Itemid),'');
echo '</div>';
<div class="hikashop_product_cart_mail_link">
<a title="<?php echo JText::_('HIKA_EMAIL');?>" class="modal" rel="{handler: 'iframe', size: {x: 760, y: 480}}" href="<?php echo hikashop_completeLink('product&task=sendcart',true); ?>">
<img src="<?php echo HIKASHOP_IMAGES; ?>go.png" alt="<?php echo JText::_('HIKA_EMAIL');?>"/>
</a>
</div>
<div class="hikashop_product_cart_print_link">
<a title="<?php echo JText::_('HIKA_PRINT');?>" class="modal" rel="{handler: 'iframe', size: {x: 760, y: 480}}" href="<?php echo hikashop_completeLink('product&task=printcart',true); ?>">
</a>
</div>
<?php
echo '</div><div class="clear_both"></div>';
$row_count = 1;
global $Itemid;
$url_itemid='';
if(!empty($Itemid)){
$url_itemid='&Itemid='.$Itemid;
if($this->params->get('small_cart')){
$this->row=$this->total;
if($this->params->get('show_cart_quantity',1)){
$qty = 0;
$group = $this->config->get('group_options',0);
foreach($this->rows as $i => $row){
if(empty($row->cart_product_quantity) && $cart_type != 'wishlist') continue;
if($group && $row->cart_product_option_parent_id) continue;
$qty+=$row->cart_product_quantity;
$text = JText::sprintf('X_ITEMS_FOR_X',$qty,$this->loadTemplate());
}else{
$text = JText::sprintf('TOTAL_IN_CART_X',$this->loadTemplate());
<a class="hikashop_small_cart_checkout_link" href="<?php echo hikashop_completeLink('checkout'.$url_itemid); ?>">
<span class="hikashop_small_cart_total_title"><?php echo $text; ?></span>
</a><?php
if($this->params->get('show_cart_delete',1)){
$delete = hikashop_completeLink('product&task=cleancart');
if(strpos($delete,'?')){
$delete.='&amp;';
}else{
$delete.='?';
<a class="hikashop_small_cart_clean_link" href="<?php echo $delete.'return_url='. urlencode(base64_encode(hikashop_currentURL('url',false))); ?>" >
<img src="<?php echo HIKASHOP_IMAGES . 'trash.png';?>" border="0" alt="clean cart" />
</a><?php
}else{
$form = 'hikashop_wishlist_form';
else{
$form = 'hikashop_cart_form';
<form action="<?php echo hikashop_completeLink('product&task=updatecart'.$url_itemid,false,true); ?>" method="post" name="<?php echo $form;?>">
<table width="100%">
<thead>
<tr>
<th class="hikashop_cart_module_product_name_title hikashop_cart_title">
<?php echo JText::_('CART_PRODUCT_NAME'); ?>
</th>
<?php if($this->params->get('show_cart_quantity',1)){
$row_count++; ?>
<th class="hikashop_cart_module_product_quantity_title hikashop_cart_title">
<?php echo JText::_('CART_PRODUCT_QUANTITY'); ?>
</th>
<?php }
if($this->params->get('show_price',1)){
$row_count++; ?>
<th class="hikashop_cart_module_product_price_title hikashop_cart_title">
<?php echo JText::_('CART_PRODUCT_PRICE'); ?>
</th>
<?php }
$row_count++; ?>
<th class="hikashop_cart_title">
</th>
<?php }
if($row_count<2){ ?>
<th></th>
<?php }?>
</tr>
</thead>
<?php if($this->params->get('show_price',1) && $this->params->get('cart_type','cart') != 'wishlist'){ ?>
<tfoot>
<tr>
<td colspan="<?php echo $row_count;?>">
<hr />
</td>
</tr>
<tr>
<?php $colspan = '1';
$colspan=2;
<td class="hikashop_cart_module_product_total_title" colspan="<?php echo $colspan; ?>">
<?php echo JText::_('HIKASHOP_TOTAL'); ?>
</td>
<td class="hikashop_cart_module_product_total_value">
<?php
echo $this->loadTemplate();
</td>
<?php if($this->params->get('show_cart_delete',1)){ ?>
<td>
</td>
<?php }?>
<?php
<td>
</td>
<?php }?>
</tr>
</tfoot>
<?php } ?>
<tbody>
<?php
$k = 0;
$this->cart_product_price = true;
$cart_id = 0;
$cart_id = $row->cart_id;
if(empty($row->cart_product_quantity)&& $cart_type != 'wishlist' || $row->hide == 1) continue;
if(method_exists($app,'stringURLSafe')){
$product_alias = $app->stringURLSafe(strip_tags($row->product_name));
}else{
$product_alias = JFilterOutput::stringURLSafe(strip_tags($row->product_name));
<tr class="<?php echo "row$k"; ?>">
<td class="hikashop_cart_module_product_name_value hikashop_cart_value">
<a href="<?php echo hikashop_completeLink('product&task=show&cid='.$row->product_id.'&name='.$product_alias.$url_itemid);?>" >
<?php echo $row->product_name; ?>
<?php if ($this->config->get('show_code')) { ?>
<span class="hikashop_product_code_cart"><?php echo $row->product_code; ?></span>
<?php } ?>
</a>
<p class="hikashop_cart_product_custom_item_fields">
<?php
if(hikashop_level(2) && !empty($this->itemFields)){
foreach($this->itemFields as $field){
$namekey = $field->field_namekey;
if(!empty($row->$namekey)){
echo '<p class="hikashop_cart_item_'.$namekey.'">'.$this->fieldsClass->getFieldName($field).': '.$this->fieldsClass->show($field,$row->$namekey).'</p>';
$input='';
if($group){
foreach($this->rows as $j => $optionElement){
if($optionElement->cart_product_option_parent_id != $row->cart_product_id) continue;
if(!empty($optionElement->prices[0])){
if(!isset($row->prices[0])){
$row->prices[0]->price_value=0;
$row->prices[0]->price_value_with_tax=0;
$row->prices[0]->price_currency_id = hikashop_getCurrency();
foreach(get_object_vars($row->prices[0]) as $key => $value){
if(is_object($value)){
foreach(get_object_vars($value) as $key2 => $var2){
if(strpos($key2,'price_value')!==false) $row->prices[0]->$key->$key2 +=@$optionElement->prices[0]->$key->$key2;
}else{
if(strpos($key,'price_value')!==false) $row->prices[0]->$key+=@$optionElement->prices[0]->$key;
<p class="hikashop_cart_option_name">
<?php
echo $optionElement->product_name;
</p>
<?php
$input .='document.getElementById(\'cart_product_option_'.$optionElement->cart_product_id.'\').value=qty_field.value;';
echo '<input type="hidden" id="cart_product_option_'.$optionElement->cart_product_id.'" name="item[cart_product_quantity]" value="'.$row->cart_product_quantity.'"/>';
</p>
</td>
<?php
<td class="hikashop_cart_module_product_quantity_value hikashop_cart_value">
<?php
if(empty($session))
$session = new stdClass();
$session->cart_id = $app->getUserState( HIKASHOP_COMPONENT.'.'.$cart_type.'_id', 0, 'int' );
if($row->cart_id == $session->cart_id && $this->params->get('from','display') != 'module'){
<input id="hikashop_wishlist_quantity_<?php echo $row->cart_product_id;?>" type="text" name="item[<?php echo $row->cart_product_id;?>][cart_product_quantity]" class="hikashop_product_quantity_field" value="<?php echo $row->cart_product_quantity; ?>" onchange="var qty_field = document.getElementById('hikashop_wishlist_quantity_<?php echo $row->cart_product_id;?>'); if (qty_field){<?php echo $input; ?> } document.<?php echo $form; ?>.submit(); return false;" />
<div class="hikashop_cart_product_quantity_refresh">
<a href="#" onclick="var qty_field = document.getElementById('hikashop_cart_quantity_<?php echo $row->cart_product_id;?>'); if (qty_field && qty_field.value != '<?php echo $row->cart_product_quantity; ?>'){<?php echo $input; ?> qty_field.form.submit(); } return false;" title="<?php echo JText::_('HIKA_REFRESH'); ?>">
<img src="<?php echo HIKASHOP_IMAGES . 'refresh.png';?>" border="0" alt="<?php echo JText::_('HIKA_REFRESH'); ?>" />
</a>
</div>
<?php
}else{
<input id="hikashop_cart_quantity_<?php echo $row->cart_product_id;?>" type="text" name="item[<?php echo $row->cart_product_id;?>][cart_product_quantity]" class="hikashop_product_quantity_field" value="<?php echo $row->cart_product_quantity; ?>" onchange="var qty_field = document.getElementById('hikashop_cart_quantity_<?php echo $row->cart_product_id;?>'); if (qty_field){<?php echo $input; ?> } document.<?php echo $form; ?>.submit(); return false;" />
<?php
if($this->params->get('show_delete',1) && $this->params->get('from','display') != 'module'){ ?>
<div class="hikashop_cart_product_quantity_delete">
<a href="<?php echo hikashop_completeLink('product&task=updatecart&product_id='.$row->product_id.'&quantity=0&return_url='.urlencode(base64_encode(urldecode($this->params->get('url'))))); ?>" onclick="var qty_field = document.getElementById('hikashop_checkout_quantity_<?php echo $row->cart_product_id;?>'); if(qty_field){qty_field.value=0; <?php echo $input; ?> qty_field.form.submit();} return false;" title="<?php echo JText::_('HIKA_DELETE'); ?>">
<img src="<?php echo HIKASHOP_IMAGES . 'trash.png';?>" border="0" alt="<?php echo JText::_('HIKA_DELETE'); ?>" />
</a>
</div>
<?php }
</td>
<?php }
if($this->params->get('show_price',1)){ ?>
<td class="hikashop_cart_module_product_price_value hikashop_cart_value">
<?php
$this->row=&$row;
</td>
<?php }
if($this->params->get('show_cart_delete',1) && $this->params->get('cart_type','cart') != 'wishlist'){ ?>
<td class="hikashop_cart_module_product_delete_value hikashop_cart_value">
<a href="<?php echo hikashop_completeLink('product&task=updatecart&cart_product_id='.$row->cart_product_id.'&quantity=0&return_url='.urlencode(base64_encode(urldecode($this->params->get('url'))))); ?>" onclick="var qty_field = document.getElementById('hikashop_cart_quantity_<?php echo $row->cart_product_id;?>'); if(qty_field){qty_field.value=0;<?php echo $input; ?> document.hikashop_cart_form.submit(); return false;}else{ return true;}" title="<?php echo JText::_('HIKA_DELETE'); ?>"><img src="<?php echo HIKASHOP_IMAGES . 'trash.png';?>" border="0" alt="<?php echo JText::_('HIKA_DELETE'); ?>" /></a>
</td>
<?php }
if($cart_type == 'wishlist' && $this->params->get('from','display') != 'module'){ ?>
<td class="hikashop_wishlist_display_add_to_cart">
<!-- Add 'ADD_TO_CART' button -->
<?php
$form = ',\'hikashop_wishlist_form\'';
$this->ajax = '
if(qty_field == null){
var qty_field = document.getElementById(\'hikashop_wishlist_quantity_'.$row->cart_product_id.'\').value;
if(hikashopCheckChangeForm(\'item\',\'hikashop_wishlist_form\')){
return hikashopModifyQuantity(\'' . $this->row->product_id . '\',qty_field,1,\'hikashop_wishlist_form\',\'cart\');
} else {
return false;
$this->setLayout('quantity');
</td>
<?php }
<td></td>
<?php }?>
</tr>
<?php
$k = 1-$k;
$this->cart_product_price=false;
</tbody>
</table>
<?php
if($this->params->get('show_cart_quantity',1)){ ?>
<noscript>
<input type="submit" class="btn button" name="refresh" value="<?php echo JText::_('REFRESH_CART');?>"/>
</noscript>
<?php }
if($this->params->get('cart_type','cart') != 'wishlist' && $this->params->get('from','display') == 'module'){
$cart_type = '&cart_type='.$this->params->get('cart_type','cart');
if($this->params->get('show_cart_proceed',1)) echo $this->cart->displayButton(JText::_('PROCEED_TO_CHECKOUT'),'checkout',$this->params,hikashop_completeLink('checkout'.$url_itemid.$cart_type),'');
else{
?><div class="hikashop_display_cart_show_convert_button"><?php
echo $this->cart->displayButton($convertText,'wishlist',$this->params,hikashop_completeLink('cart&task=convert'.$url_itemid.$cart_type),'window.location.href = \''.hikashop_completeLink('cart&task=convert'.$url_itemid.$cart_type).'\';return false;');
else{
echo $this->cart->displayButton($displayText,'wishlist',$this->params,hikashop_completeLink('cart&task=showcart&cart_id='.$cart_id.$url_itemid.$cart_type),'window.location.href = \''.hikashop_completeLink('cart&task=showcart&cart_id='.$cart_id.$url_itemid.$cart_type).'\';return false;');
?></div><?php
<input type="hidden" name="url" value="<?php echo $this->params->get('url');?>"/>
<input type="hidden" name="ctrl" value="product"/>
<input type="hidden" name="task" value="updatecart"/>
</form>
<?php } ?>
</div>
<?php } ?>
<?php
if(JRequest::getWord('tmpl','')=='component'){
header('Content-Type: text/css; charset=utf-8');
exit;
13 years 6 months ago #98063 by nicolas
If the code from www.hikashop.com/en/forum/4-how-to/77022...rt-module.html#98045 works for you you should go with that.
For the print view, you can simple change the line:
<?php if($tmpl != 'component'){ ?>
<?php if(true){ ?>
in the file 'showcart' of the view 'cart' via the menu Display->Views.
13 years 6 months ago #98250 by mirlinda.kosova
Thank you! It is working now. My problem is that when you open link for the first time it opens the cart on a full normal browser window. Only when you click the link View cart for the second time the lightbox effect works. Have you heard about this kind of problem before?
For example same lightbox effect that is used for product added to cart pop up works just fine.
/Mirlinda
13 years 6 months ago #98270 by mirlinda.kosova
To be more specific I am using this code:
<a class="modal" rel="{handler: 'iframe', size: {x: 560, y: 280}}" href="<?php echo hikashop_completeLink('cart&task=showcart',true); ?>">Shiqo shportën</a>
the only problem is that sometimes cart opens full blank window with only cart on it. Modal light box sometimes works and sometimes not.
13 years 6 months ago #98323 by Xavier
This should work every times. Can you check if the code to load the modal popup is present in the index.php file of your template ?
13 years 6 months ago #98348 by mirlinda.kosova
Hi!
If you mean JHTML::_('behavior.modal'); couldn't locate it from index.php template file.
Should I put it there? And if so than should I put it on the head section or somewhere else?
13 years 6 months ago #98373 by Xavier
Yes you have to add it in the head section of your template index.php file.
<?php JHTML::_('behavior.modal'); ?>
Time to create page: 0.223 seconds
