Problem : HikaShop & Rockettheme responsive menu
13 years 7 months ago - 13 years 7 months ago #98285 by nico.van.leeuwen
It looks like there is a problem with the combination of HikaShop and my Rockettheme Graffito template when viewing the site on a small screen.
The links in the menu are not clickable anymore ??
As soon as I unpublish the HikaShop menu's the menu works again. ( www.dli.dlidev.nl/ )
Can this me something in my configuration or should this be considered a bug of some sort ?
Any tips are more than welcome !
Nico
Last edit: 13 years 7 months ago by nico.van.leeuwen.
13 years 7 months ago #98286 by Jerome
It's a problem with the Joomla JUI Chosen library.
You should activate an hidden option in order to force HikaShop to unload it.
In the database, in the table #__hikashop_config (replace #_ with your database prefix), you have to insert a new entry.
config_namekey: bootstrap_forcechosen
config_value: 0
INSERT INTO `#__hikashop_config` (`config_namekey`, `config_value`) VALUES ('bootstrap_forcechosen', '0');
The following user(s) said Thank You: nico.van.leeuwen
13 years 7 months ago #98289 by nico.van.leeuwen
Hi Jerome,
That indeed did the trick !
Many thanks for the quick response.
Nico
12 years 8 months ago #147122 by Zafer
Hi Jerome,
i use Rockettheme Templates. How can i enjoy the Hikashop Resposive feature.
Zafer
12 years 8 months ago #147152 by Jerome
If your rockettheme responsive template is fully compatible with bootstrap, you can activate the "bootstrap design" in the HikaShop configuration.
12 years 8 months ago #147275 by Zafer
Hi Jerome,
Thank you for your fast response. I activate bootstrap design. Now the category and product listening will be displayed on a iPhone and Smartphone in a 1 column. Thats O.K. but it will be also displayed in 1 column categories and product listenings on a big screen.
After set 3 columns in main CSS Main Module. No changes!
How can I set up custom fields also for responsive design?
How can I set 3 columns for category listening and Product listening?
regards
12 years 8 months ago #147307 by Zafer
Column problem solved. renew Template Custom CSS. O.K
Can´t solve problem about the custom fields.
regards
12 years 8 months ago #147322 by Jerome
Please put a full complete question about your custom field.
There are a lot of different kind of custom field and there are a lot of way to display them.
Your question is too generic so I can't give you any kind of answer.
12 years 8 months ago #147622 by Zafer
sorry for the inaccurate question. I have a problem with input and custom fields when i use a iPhone. Please look at the screenshoots.
Bootstrap design ist activated.
How can fix it?
Zafer Gürsyo
12 years 8 months ago #147820 by Xavier
That's probably because your template override some HikaShop css properties.
Thanks to read that tutorial to edit the css in order to improve the responsive.
hikashop.com/support/support/documentati...ize-the-display.html
