Problem with the accordion vertical menu module
13 years 5 months ago #100107 by vilo
Hello.
I have a problem with the accordion vertical menu module of HikaShop.T
he subcategories are all together and I want each category is displayed one per line.
Deputy capture the problem.
Is there any way to fix it?T
hank you very much from now.
13 years 5 months ago #100268 by Jerome
I guess that is not a problem with the accordion vertical menu but with one of your CSS rules.
The content of the accordion is a list made with "ul / li" and I think you have a CSS rule which change the vertical listing of this "ul / li" into a horizontal listing (by adding a "float: left;").
You have to add a new specific rule for the accordion in order to remove the "float: left" for the "ul / li" of the accordion (using the unique id of the main div of the module).
13 years 5 months ago #100270 by vilo
Thank you very much for your reply.I do not know much about css, I'd appreciate a guide to know which files and edit lines.From already thank you very much.
13 years 5 months ago #100306 by Jerome
Without any link to your website, I can't see what is the source of your problem. So I can't give you the solution.
Would it be possible to have a link to your site ?
13 years 5 months ago #100309 by vilo
I send it by private message
13 years 5 months ago #100343 by Jerome
In your custom CSS file, you have the rule:
.hikashop_category_list_item, .hikashop_product_list_item{ float:left; }
By removing it, the list would be displayed vertically.
13 years 5 months ago #100348 by vilo
Jerome:
Thank you very much it worked to perfection!
Time to create page: 0.245 seconds
