Get Wishlist products
7 years 4 months ago #306998 by kyratn
Get Wishlist products was created by kyratn
I am looking for a way to show wishlist products inside cart module? Both wishlist and cart modules use same view "cart.php".
The main idea is to have cart module, customize cart.php file to show also wishlist products without need of wishlist module at all.
Any advise?
Thank you
7 years 4 months ago #307005 by nicolas
Replied by nicolas on topic Get Wishlist products
The simplest would be to make a copy of the mod_hikashop_cart module.
In that copy, you could combine in each file the code of each file of mod_hikashop_cart and mod_hikashop_wishlist.
The following user(s) said Thank You: kyratn
7 years 4 months ago #307041 by kyratn
Replied by kyratn on topic Get Wishlist products
Thanks Nicolas for pointing to this. Just created new module based on hikashop cart module and loaded my own html layout. That also solved other issues i had before.
Thanks again!
7 years 4 months ago #307071 by kyratn
So it seems i still a bit struggling in what i want to achieve.
We use hikashop cart module on some page to show it's content. All works fine until we decided to add wishlist module below. So user could add products from wishlist to cart and Vice versa...
Now we load our custom layouts which is based on cart.php for hikashop cart module and hikashop wishlist module The issue is that i need to check if hikashop cart module is empty or not and then hide wishlist layout too... The only i could find is this:
($this->element->cart_type == 'cart')
But this returns cart_type. How can i find if cart_type cart have some products inside or not?
Been searching for it like 2 hours and i think it will be easier to ask this time.
Thank you
7 years 4 months ago #307081 by nicolas
You have access to the array of products in $this->element->products and $this->rows.
So you can do a count on these.
If(count($this->element->products)) {
echo 'cart is not empty';
Time to create page: 0.174 seconds
