Removing item from cart using Ajax
- brainforge
6 years 2 months ago - 6 years 2 months ago #321920
by brainforge
Removing item from cart using Ajax was created by brainforge
-- HikaShop version -- : 4.2.3
-- Joomla version -- : 3.9.19
-- PHP version -- : 7.3.19
I have the following item line in the cart.
To change the quantity want the user to click the refresh icon.
Want that to remove the item from the cart and return user to the product page so they can re-enter quantity.
There might be other better / simpler ways of achieving the same result.
If I allow the user to update the quantity field it does not update the weight.
User orders 1.5KG - cart shows quantity of 1 and weight (custom field) of 1.5.
If user changes quantity to 2 - the shop staff think they want 2 packs of 1.5kg not 1 pack of 2kg!!
The code I have for this in show_block_cart.php is:
The item does not get deleted from the cart and the xhr.responseText response is Please enter a value for the field.
See line 1280 of file hikashop.js.
The Ajax URL is:
/checkout/product/updatecart/quantity-0/cid-1461.html?tmpl=raw
The Ajax post parameters are:
cart_type=cart&cart_id92300&cart_product_id=150694
Suggestions?
One other issue will need to address is that the Ajax call needs to be synchronous.
Otherwise replacing the alert with window.location = "..."; won't work!
<?php>
echo $item->lengthm . ' kg'; // lengthm is a custom item field - naming convention??...
$url = hikashop_contentLink('product&task=show&cid=' . $product->product_id . '&name=' . $product->alias . $url_itemid, $product);
$delete_url = hikashop_completeLink('/product&task=updatecart&product_id='.$product->product_id.'&quantity=0');
<input id="hikashop_checkout_quantity_<?php echo $product->cart_product_id;?>"
type="hidden" name="checkout[cart][item][<?php echo $product->cart_product_id;?>]"
data-hk-qty-old="<?php echo $product->cart_product_quantity; ?>"
value="<?php echo $product->cart_product_quantity; ?>"/>
<div class="hikashop_cart_product_quantity_refresh">
<a class="hikashop_no_print"
data-cart-type="<?php echo $this->escape($cart->cart_type); ?>"
data-cart-id="<?php echo (int)$cart->cart_id; ?>"
data-cart-product-id="<?php echo (int)$product->cart_product_id; ?>"
href="<?php echo $delete_url; ?>"
onclick="window.hikashop.deleteFromCart(this, null, false); alert('Go to product URL'); return false;">
<i class="fa fa-sync"></i>
</a>
</div>
The Ajax URL is:
Suggestions?
Last edit: 6 years 2 months ago by brainforge.
- brainforge
6 years 2 months ago - 6 years 2 months ago #321924
by brainforge
Replied by brainforge on topic Removing item from cart using Ajax
Does not solve the problem of how to allow the user to update the item value, but this screenshot illustrates 3 different ways in which the quantity / weight information could be displayed. Displaying 2 of 1.5kg looks like a quick fix for now - leaving out the refresh icon, leaving in the delete icon.
6 years 2 months ago #321937
Replied by nicolas on topic Removing item from cart using Ajax
How about updating to HikaShop 4.3.0 ?
With the 4.3.0 release, we introduced the cart product edition interface.
You'll get an edit icon next to the name of products with custom item fields / characteristics in the cart so that the customer can change the value of the custom fields / characteristics of the product in the cart.
- brainforge
6 years 2 months ago #321956
by brainforge
Time to create page: 0.190 seconds
