Changing Main Tax Zone does not work
14 years 5 months ago #53945 by j.buenzli
Hi.
I try to change the main tax zone in my configuration. Pressing the edit button right to the field I get to the selection list. After selecting "Switzerland" and pressing the "OK" button in the upper right corner to accept the selection I just see "204 Switzerland" in my browser window and that's it.
What am I doing wrong?
Best regards,
Juerg
14 years 5 months ago #54008 by nicolas
Maybe a javascript error. Could you try to donwload again Hikashop from our website and install it on your website on top of your existing version ?
If that still doesn't work, could you try with a different browser ?
14 years 5 months ago #54034 by j.buenzli
Hi.
Thank you for your support. Unfortunately the two proposed actions didn't help. I have two joomla instances of the same version (1.5.26) and similar configurations. In one instance (the older one, which has been upgraded form former versions) the problem still exists. In the other, which I've installed recently, Hikashop was running fine. Do you have any idea which difference could lead to this behaviour?
Best regards,
Juerg
14 years 5 months ago #54106 by nicolas
Which version of Hikashop are you using ?
Do you use the default back end template of Joomla ? If not, could you try to change to the default one ?
Also, could you look at the javascript error console of your browser while changing the main tax zone ? Do you get any error ? Especially once you click on OK in the popup ?
14 years 5 months ago #54115 by j.buenzli
I'm using HikaShop 1.5.8.
Yes, I'm using the standard back end template "Khepri".
I get the following javascript errors:
[18:04:09.360] $ is not a function @ .../media/system/js/mootools.js:23
[18:04:09.707] $ is not a function @ .../main/administrator/templates/khepri/js/index.js:27
[18:07:38.001] $ is not a function @ .../main/media/system/js/mootools.js:25
[18:07:47.795] $ is not a function @ .../main/media/system/js/mootools.js:23
[18:07:54.052] $ is not a function @ .../main/media/system/js/mootools.js:23
[18:08:00.910] $ is not a function @ .../main/media/system/js/mootools.js:23
[18:12:12.140] $ is not a function @ .../main/media/system/js/mootools.js:23
[18:12:24.915] $ is not a function @ .../main/media/system/js/mootools.js:23
14 years 5 months ago #54117 by nicolas
That means that you have a plugin which loads the jquery javascript library on your back end and it breaks the mootools library of joomla...
You could try to install and publish the jquery easy plugin to avoid that. Make sure that you enable it in the back end too.
The following user(s) said Thank You: j.buenzli
14 years 5 months ago #54145 by j.buenzli
Hi Nicolas.
Thank you very much for your support. The installation of the plug-in helped!!!
Best regards,
Juerg
