Hikashop wrong tax calculation at diffrent place
13 years 1 month ago - 13 years 1 week ago #129724 by christian13
-- Joomla version -- : 3.1.5
-- PHP version -- : 5.4
-- Browser(s) name and version -- : Firefox 24
I am in test phase.
When I order a product that is NOT configured with a caracteristic, the tax is well calculated on the order email.
When I order a product that is configured with a caracteristic, the tax is NOT well calculated on the order email.
When I show the Best Seller, it shows the price without tax of product that is configured with a caracteristic.
As the Tax is not well managed, when I generate the AttachSerial linked to this kind of product then the End Date is not added on the coupon generated.
I need help if you could double check my configuration.
see attached files
Order B3P6 is for a product without caracteristic. VAT is not well calculated and price should be with tax on the coupon and it is not the case. The End Date is not shown as well.
Order U18 is for products with caracteristic and even if the tax is configured it is not well calculated and not shown on the order email.
Additionnaly to this, on the coupon even if I selected price incl. tax the price is shown without tax. It should be 79 and not 58.53.
Do you have any idea how I can get something good?
Thanks for your help
If you need to access to my admin page, I can give you access.
Best Regards
Christian
Last edit: 13 years 1 week ago by christian13.
13 years 4 weeks ago #129903 by nicolas
Unfortunately, the PDF that you provided are slashing half of the emails so we can't see anything and you don't give much information on how you configured your taxes or your coupons either.
Could you please provide that so that we can give a precise answer ?
13 years 3 weeks ago - 13 years 3 weeks ago #130730 by christian13
Hi Nicolas
Here you'll find some scrennshots about our tax configuration.
The last file order_product_tax_0 shows that most of the time tax is not associated with the product in the database.
My first post what opened to Hikaserial team (Jerome) and he said that the issue comes from [strike]Hikaserial[/strike] Hikashop.
Let me know if you need more information to help me.
Do you need to access to my admin?
Christian
Last edit: 13 years 3 weeks ago by christian13.
13 years 3 weeks ago #130740 by Jerome
Just to clarify what I said:
Le problème de TVA est un soucis HikaShop, si l'information n'est pas présente en base de données HikaSerial ne pourra malheureusement rien faire de plus.
HikaSerial is not involved so, in another words : the issue does |b]not[/b] come from HikaSerial.
You're welcome
13 years 3 weeks ago #130741 by nicolas
Please provide a backend access to the website via our contact form so that we can check your tax settings.
13 years 3 weeks ago #130756 by christian13
Jerome
Sorry, I would like to say. "The issue doesn't come from Hikaserial but from Hikashop"
Rgds
Christian
13 years 3 weeks ago - 13 years 1 week ago #130769 by christian13
Nicolas
If you test, the site is http://www/ not the one you tried to use around 2pm today.
thx / merci
Christian
13 years 3 weeks ago #130826 by nicolas
Bizarre, tout à l'air configuré comme sur l'autre site...
Je ne comprends pas.
J'ai essayé d'activer le mode débug de la configuration de joomla mais je me retrouve avec l'erreur:
Fatal error: Out of memory (allocated 26476544) (tried to allocate 1855760 bytes) in /homepages/36/d210733560/htdocs/BTJ315/plugins/system/debug/debug.php on line 1070
Serait-il possible d'augmenter la limite mémoire pour pouvoir activer le mode débug sur le site ?
13 years 3 weeks ago #130865 by christian13
Bonjour
J'ai configuré comme mon site de test d'il y a 7-8 mois.
Les versions sont différentes.
J'ai mis php_value memory_limit 32M dans htaccess
cdlt
Christian
13 years 3 weeks ago #130866 by christian13
bon chez 1and1 en mutualisé je ne peux pas changer la memory_limit !
13 years 3 weeks ago - 13 years 3 weeks ago #130900 by christian13
J'ai un backup Akeeba de mon site, si cela peut aider.
13 years 3 weeks ago #130964 by nicolas
Serait-il possible d'avoir un accès FTP au site alors ?
13 years 3 weeks ago #130980 by christian13
13 years 2 weeks ago #131492 by christian13
Nicolas
Avez-vous reçu mes accès FTP?
cdlt
Christian
13 years 2 weeks ago #131880 by nicolas
J'ai trouvé le soucis. Tous vos produits n'étaient pas liés à la catégorie de taxe France que vous avez créé.
J'ai créer une action en masse pour forcer cela sur tous les produits et cela fonctionne maintenant.
The following user(s) said Thank You: christian13
13 years 2 weeks ago #131905 by christian13
Bonjour Nicolas
Merci infiniment.
J'ai passé une commande et la calcul de la TVA était bon donc bravo.
Savez-vous m'envoyer la commande que vous avez utilisé pour forcer la TVA sur tous les produits?
Sinon, je n'ai toujours pas la date de validité qui s'affiche sur mon bon Hikaserial. Je vais continuer mes recherches mais Jerome va peut-être trouver.
Encore merci je continue mes tests.
Cdlt
Christian
13 years 2 weeks ago #131923 by nicolas
Allez dans le menu Système>Actions en masse et vous trouverez cela.
13 years 2 weeks ago #131991 by christian13
Bonjour Jerome
Je reviens vers vous car depuis que Nicolas a fait la correction côté Hikashop, je ne vois toujours pas la date de validité s'afficher dans le bon.
Avez-vous une nouvelle piste?
cdlt
Christian
13 years 2 weeks ago #132118 by nicolas
Pour la date de validité il faut la configurer dans le plugin de génération de coupon de HikaSerial comme Jérome vous l'avait indiqué auparavant. Les deux questions ne sont pas liées entre elles.
13 years 1 week ago #132154 by christian13
Nicolas
En fait, je pense avoir configuré la date de validité en utilisant le plugin attachserial comme je l'avais fait il y a quelques mois avec la version precedente. Cela fonctionnait très bien mais avec cette version et la même config ce n'est plus le cas.
voir mon fichier attaché
cdlt
Christian
Time to create page: 0.120 seconds
