- Thank you received: 10
Error applying VAT when using general discount
-- Joomla version -- : 3.3.5
-- PHP version -- : 5,4
Just setup the new VAT rules (thanks for the easy way to do this) and found something that seems an bug.
we had one product that had a 10% discount applied. For my country (NL) all 3 rates are set to charge 21% VAT.
VAT system set to FLOAT.
That works fine but if I enable the discount I get funny issues: companies with VAT suddenly need to pay an extra 21%
Individuals don't pay VAT etc.
Seems the general discount is interfering with the prices and how VAT is calculated.
No one reported such issue and we cannot reproduce the problem.
So I can only deduce that the problem comes from how you configured your tax rules.
Please edit each tax rule for your country and provide a screenshot of the option screen of each one.
Also, please provide a screenshot of the issue with the price before/after discount being displayed on the checkout with the address displayed.
Setting: standard customer in the Netherlands:
VAT 21%:
The customer order 2 identical products, (made a copy). One with 10% discount the other not:
As you can see, one gets VAT applied, the other not.
Tax settings in config:
Curious whats going on.
That is a new option we introduced in the 2.3.5 and I wouldn't be surprised that it would have some issue with discounts.
How did you configure your discount ? Could you do a screenshot ?
Could you try to turn off the "floating tax prices" option and see if that helps ?
Not the only one working late.....
Yes it seems to come from the FLOAT tax. Switched it off and at least the VAT issue seem less.
Have done a few combination tests, als going back to 'default' tax system etc but that wasn't changing much.
Discount is pretty simple. just 10% on that specific product.
Removing FLOAT seems to help but there are still a few more calculations that don't add up exactly when I use two discount and one overriding.
Time to stop and work on it tomorrow.
I think that I've found the issue with the "Floating tax prices" option and the discount calculations.
Add the code:
It fixes the issue on my end in the few tests I did.
Do you have the "Floating tax prices" option activated ?
If you switch the "Apply discount" option of the HikaShop configuration, does it work ? I have it set to "Before taxes" on my end.
So for testing: floating set and taxes before:
When I have no discount, it show inc and excl taxes ok
When I set a discount, taxes before, it seems ok
I get the same incl and excl prices when I switch back to after taxes.
So the issues is indeed when set to discount after tax
Coupons seem to work OK. (although we had to change them all and give them a VAT select to get the same prices back again.)
Bastiaan
I'm trying to continue this thread and I'm a little bit confused.
Would it be possible to have a description of the configuration which provide a wrong result ?
So I will be able to set a sample store using that and fix the issue directly in the code (and then, provide you a fix).
Thanks !
Setting: VAT set to FLOAT, apply discount after TAX. That seems to mess up the VAT calculation when using an overal discount. (not coupon)
Shop is using prices included VAT but see this invoice when someone enters his VAT number while in a country without exempt:
(Dutch company buying in NL from our Dutch shops)
Some crooked calculation pops up. Instead of the proper 347, he has to pay a strange amount. We are now serious in trouble with a bunch of clients and overloaded helpdesk..
We have set the VAT amount for companies in the Netherlands equal to consumer amount. With or without VAT number:
When Nicolas implemented the floating tax mode ; some users has test it in order to validate it.
Nicolas also made a bunch of tests in order to be sure that it is working properly.
Unfortunately, some elements have not been tested and the problem you are seeing now are, I think, all links to the floating tax option.
I finally got it !
So, please edit the file "administrator/components/classes/currency.php" and replace
I made some tests and some checks ; the modifications does not seems to have bad side effects.
Let me know if you have any feedback on that patch.
Yes it works now for a general discount and VAT seems ok, although I will have to test a bit more tomorrow with and without VAT number.
but coupons still don't work right. My settings is still apply discount after tax but the coupon code still takes discount before tax.
Of course I have a complicate example: product receives 10% discount and then people can add a 50% discount coupon that should override. 50% of 1388 = 694. Not whats on the sheet now:
I was focused on the discounts for my tests and I didn't test the coupons.
It is for coupons or just when there is a "discount + coupon" ?
I'll perform some new tests for that.
Don't hesitate to send me more information if you find other problems.
Without Float setting it seems ok.
I performed several tests using floating taxes and coupons (apply on products or not, fixed and percentage...)
Thanks to these tests (and some aspirins), I made some patches for the coupons and I got know good results.
So here the new version of the function "addCoupon" in the currency class
Replaced the class but discount is still applied before taxes. Switching that option in the config does not change the numbers.
Checked it only with a very basic product (ID=1) and a coupon.
Also switching tax category in the coupon setting does not change the amounts so it seems to miss those values completely.
For security of testing it might be safer to attach or email the full currency.php file.
I'll need more details about your coupon in order to reproduce it.
My tests looks good so it will be difficult to know what I have to fix now !
