Products listing blank : nothing
- adrien5555
14 years 6 months ago - 14 years 6 months ago #46025
by adrien5555
Products listing blank : nothing was created by adrien5555
Hello folks,
I've come to try Hikashop, which seems cooler and simpler than VM. Doc is well done and straight forward, which is valuable.
But for the simple thing i wanna do, i just got headaches... Please Help !
I want to have a menu item pointing to the Hika product listing
I created 3 products in a new category. BTW, what is "2 product category", the PARENT category ?
Nothing is displayed on the front end but the Hikashop Trademark. :blink:
BTW, a confusing thing ...After saving Menu Content, all fields get reset. It makes testing very difficult in my opinion.
Config :
J2.5.3 on a local xampp server PHP 5.2.8
hikashop starter installed
other extensions installed too, among them is virtueMart, may that cause conflicts ?
Thanks for helping, this component really seems cool....
edit : i have the same symptoms than described in this topic
Config :
Last edit: 14 years 6 months ago by adrien5555.
14 years 6 months ago #46135
Replied by nicolas on topic Re: Products listing blank : nothing
If you can't save the hikashop options of your menus it might be due to a cookie/cache issue on your browser. Please try with another browser to see if that helps.
Regarding the creation of a listing of products, the simplest is to create your menu by following the tutorials on that page:
www.hikashop.com/en/support/documentatio...splay-front-end.html
14 years 6 months ago #46165
by mjokc
Replied by mjokc on topic Re: Products listing blank : nothing
I am having the exact same issue, when I try to create a Products Listing and set the associated category, it will not save and reset itself back to "2 product category" whenever I press the save button. It is not a browser issue as I have tried 3 different browsers with same issues. Also have cleared all temp files, cache, cookies, etc.
- adrien5555
14 years 6 months ago #46174
by adrien5555
Replied by adrien5555 on topic Re: Products listing blank : nothing
hello Nicolas & mjokc,
after testing a fresh joomla install with Hikashop, product listing and saving the settings was working perfectly.
So i uninstalled VM and Hikashop, reinstalled Hikashop, recreated a menu item, and from then, saving was working and the rpoduct listing display well.
14 years 6 months ago #46175
@mjokc : You must not be selecting the category properly in the popup.
Please make sure that you click on the category name on the RIGHT area, not in the explorer on the left which will only display the sub elements of your category.
