Need to click twice on "add to cart" in firefox...
- rian.groenewald
14 years 2 months ago #60737
by rian.groenewald
Like the title said, for some reason I have to click twice on the "add to cart" button in my shop when using firefox. Chrome and IE works fine.
Using joomla 2.54 and hikashop starter 1.5.9
14 years 2 months ago #60748
by Jerome
Replied by Jerome on topic Re: Need to click twice on "add to cart" in firefox...
Please edit the file administrator/com_hikashop/helpers/cart.php
And replace this part of code (which is twice in the file) :
By:
It should fix the problem with firefox.
if(varform){
varform.action = "'.hikashop_completeLink('product&task=updatecart',false,false).'";
varform.submit();
if(varform){
varform.submit();
- rian.groenewald
14 years 2 months ago #60762
by rian.groenewald
Replied by rian.groenewald on topic Re: Need to click twice on "add to cart" in firefox...
Hi Jerome,
Thanks for the fix and the quick reply - it is working now!
