weights are not inherited by characteristics for t
14 years 2 months ago #62706 by EdQ
he USPS shipping module, in particular [<== Continued Subject field from limited input area.]
add a product category, say "my shirts"
add a product characteristic, say "size"
add three values, say "small", "medium" and "large"
add a product of that category and add the "size" characteristic
set price, weight and dimensions on the product
under manage variants:
1. change the price of the "large" to a value different from that of the main product listing
2. change the weight to a value different from that of the main product listing.
The price value of the main listing is inherited by "small" and "medium" selections, and that of the "large" is handled correctly.
The USPS shipping module does not recognize the inheritance of the main product's weight value by the "small" and "medium" product variants, and it will not appear during the checkout sequence because it assumes they have zero weight.
If you force the weight values into those two variants, copying them from the main product, the plugin suddenly shows up and starts working.
The UPS plugin doesn't appear to have this problem.
14 years 2 months ago #62844 by Mohamed Thelji
Can you test it with weight into your variants and without the "Force shipping regardless of weight", then if the UPS method don't show can you send me a screenshot of your UPS configuration ?
14 years 2 months ago #62846 by EdQ
I'm actually in the process of forcing weights into all the variants. (75 variants to edit...) This does definitely fix it.
"Force shipping regardless of weight" as been off all along.
Why do you want UPS? It's USPS that's the problem.
14 years 2 months ago - 14 years 2 months ago #62854 by Mohamed Thelji
Sorry I misunderstood :
We are working on it and will fix it tonight if everything goes fine.
Last edit: 14 years 2 months ago by Mohamed Thelji.
The following user(s) said Thank You: EdQ
14 years 2 months ago #62914 by nicolas
We published the new build and it should work now. Please download and install HikaShop again.
