Product 'Kits' . . . not options
14 years 1 week ago #71646
by 4xjbh
Product 'Kits' . . . not options was created by 4xjbh
Are there any plans to add this to HS?
It is easy enough with most carts to create a product with multiple options, lets say a M3 Bolt with size options of 10mm, 20mm, 30mm and skus on each option for stock control. But as soon as you want to create a 'Kit' that has 25 M3 10mm bolts and 6 M3 30mm bolts, 3 50mm x 5mm x 500mm aluminium plate etc . . . . no cart except for the expensive ones can do it. There are always exceptions like you cannot add a child product to a kit if the child has options (forcing you to create a separate product for each of the bolts etc (10,20 & 30mm). Volusion, shopify, and all of the other carts cannot do it.
How about it HikaShop? Kits as an extra module (like the serials) or included as part of the Business package.
Regards, James
Regards, James
14 years 1 week ago #71906
Replied by nicolas on topic Re: Product 'Kits' . . . not options
It's in the todo list. We didn't had the time to look at it so far but we'll come to it.
We were thinking of having it integrated in HikaShop directly, but it could be proposed as an extra module too.
We didn't start looking at that yet.
