Pagination problem
13 years 11 months ago #80156 by sheraz
Pagination problem was created by sheraz
The issue i am facing is with the seo turned on or off in both cases the pagination works fine but does not effect the url at all. as a result lets say if the user is at second page of the pagination and clicks to a different page lets say Contact Page and then comes back by either pushing the back button or clicking the store url again (same url where pagination was). the user is taken to the last state i.e. Page 2 of the pagination. It should reset to the first page as soon as the user browses away.
13 years 11 months ago #80184 by Mohamed Thelji
Replied by Mohamed Thelji on topic Pagination problem
I didn't really understood the problem that you are facing, but can you give me a link to your web site ?
The following user(s) said Thank You: sheraz
13 years 11 months ago #80186 by sheraz
Replied by sheraz on topic Pagination problem
creativecellutions.com/bbmg/ this is the main url
Click on Merchandise
creativecellutions.com/bbmg/merchandise.html
You will see the products list and at the bottom the pagination .. click on "2" for the second page ans the second page loads but you will notice the url creativecellutions.com/bbmg/merchandise.html remains the same.
now if you click on any other link such as Contact etc. and then click again on Merchandise it loads the "Page 2" again where it should load the first page "Page 1"
13 years 11 months ago #80237 by nicolas
Replied by nicolas on topic Pagination problem
Yes, the pagination is saved in the user session so that the user can more easily browse the store nd go back where he was instead of having to go againt o the same page of the listing when going back in the listing.
It's not a bug, it's a feature.
The following user(s) said Thank You: Jerome, Mohamed Thelji, sheraz
13 years 11 months ago #80286 by sheraz
But if the client demands it is there a way we can turn it off?
13 years 11 months ago #80314 by Jerome
Replied by Jerome on topic Pagination problem
You can add in your listing views (products, category)
$app = JFactory::getApplication(); $app->setUserState($this->paramBase.'.limitstart', 0);
It would be erase the value in session so, it would only change the page when the value would be pass by post/get.
13 years 11 months ago #80341 by sheraz
Thanks jerome yr a lifesaver :)
