please help me!. carousel not working .
13 years 3 months ago #113773 by akmal_okey
this not slide automatic and not slide if i click button next or perivious in carousel button
this my link grosircibaduyut.p.ht/
and this pictures capture configuration .
13 years 3 months ago #113871 by Eliot
Hi there,
You have this javascript error caused by your template:
Uncaught exception: TypeError: 'jq('.lv-tooltip').tooltip' is not a function
Error thrown at line 29, column 1 in <anonymous function>(jq) in grosircibaduyut.p.ht/templates/allrounder-3/js/effects.js :
Since it's loaded before Hikashop carousel, the error prevents our code to be loaded.
Try to fix this error first and the carousel should work :)
The following user(s) said Thank You: akmal_okey
