Quantity set to unlimited, max 15 when add to cart
10 years 7 months ago - 10 years 7 months ago #235908 by nuntius
-- Joomla version -- : 3.5.1
-- PHP version -- : 5.4.45
-- Browser(s) name and version -- : Chrome latest
-- Error-message(debug-mod must be tuned on) -- : "Niet genoeg voorraad" which is dutch for not enough in stock (quantity)
For some reason all products with an unlimited quantity (in stock) in Hikashop now have a max limit of 15 for adding to the cart. This happened since the latest update of Joomla (3.5.1) and Hikashop (2.6.2).
The exact error is a javascript alert saying "Niet genoeg voorraad" which is dutch for not enough in stock (quantity). The product configuration however says the stock is unlimited. When I change the stock to a number it works fine.
How can I solve this?
Last edit: 10 years 7 months ago by nuntius.
10 years 7 months ago #235915 by nicolas
I don't think that it's linked to that setting of your HikaShop configuration.
I think that it comes from the min max settings of each product.
Could you provide a screenshot of the settings of one of your products with the issue ?
10 years 7 months ago #235957 by nuntius
Ofcourse!
Here is one example. The settings are all the same for the products, except price ofcourse.
10 years 7 months ago #236123 by Xavier
Please edit the view "product / show_quantity" and replace:
$max_quantity = ($this->params->get('max_quantity'))?$this->params->get('max_quantity'):(int)$min_quantity * 15;
By:
$max_quantity = $this->params->get('max_quantity','0');
And add the code:
if(!$max_quantity) $max_quantity = (int)$min_quantity * 15;
After:
case 'show_select':
And:
case 'show_select_price':
Thank you for this report.
The following user(s) said Thank You: nuntius
10 years 7 months ago #236524 by cesarlab69
I do what you say Xavier, and the problem persists, products width a unlimited stock has a limit of 15 to add to cart
10 years 7 months ago #236525 by nuntius
Make sure you remove any custom view before adding these modifications to make this work. At least that was the case with my webshop.
Cheers,
Teeuwis
10 years 7 months ago #236527 by cesarlab69
thanks Nuntius, now its OK ;)
10 years 6 months ago - 10 years 6 months ago #238860 by lyshytten
have tried but it does not
try to see the file if it is right
Last edit: 10 years 6 months ago by lyshytten.
10 years 6 months ago - 10 years 6 months ago #238872 by Xavier
Please use that version of the view:
<?php $i = $this->params->get('i'); $min_quantity = ($this->params->get('min_quantity'))?$this->params->get('min_quantity'):1; $max_quantity = $this->params->get('max_quantity','0'); $html = $this->params->get('html'); $qLayout = JRequest::getVar('quantitylayout','show_default'); switch($qLayout){ case 'show_none': ?> <div class="hikashop_product_quantity_div hikashop_product_quantity_add_to_cart_div hikashop_product_quantity_add_to_cart_div_regrouped"> <?php echo $html; ?> </div> <?php break; case 'show_regrouped': ?> <div class="input-append hikashop_product_quantity_div hikashop_product_quantity_input_div_regrouped"> <input id="hikashop_product_quantity_field_<?php echo $i; ?>" type="text" value="<?php echo JRequest::getInt('quantity',$min_quantity); ?>" class="hikashop_product_quantity_field" name="quantity" onchange="hikashopCheckQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);" /> <div class="add-on hikashop_product_quantity_div hikashop_product_quantity_change_div_regrouped"> <div class="hikashop_product_quantity_change_div_plus_regrouped"> <a id="hikashop_product_quantity_field_change_plus_<?php echo $i; ?>" class="hikashop_product_quantity_field_change_plus hikashop_product_quantity_field_change" href="#" onclick="return hikashopQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',1,<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);">+</a> </div> <div class="hikashop_product_quantity_change_div_plus_regrouped"> <a id="hikashop_product_quantity_field_change_minus_<?php echo $i; ?>" class="hikashop_product_quantity_field_change_minus hikashop_product_quantity_field_change" href="#" onclick="return hikashopQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',0,<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);">&ndash;</a> </div> </div> </div> <div class="hikashop_product_quantity_div hikashop_product_quantity_add_to_cart_div hikashop_product_quantity_add_to_cart_div_regrouped"> <?php echo $html; ?> </div> <?php break; case 'show_select': if(!$max_quantity) $max_quantity = (int)$min_quantity * 15; ?> <div class="hikashop_product_quantity_div hikashop_product_quantity_input_div_select"> <select id="hikashop_product_quantity_select_<?php echo $i; ?>" onchange="var id = this.id.replace('select','field'); document.getElementById(id).value = this.value;"> <?php for($j = $min_quantity; $j <= $max_quantity; $j += $min_quantity){ echo '<option value="'.$j.'">'.$j.'</option>'; } ?> </select> <input id="hikashop_product_quantity_field_<?php echo $i; ?>" type="hidden" value="<?php echo JRequest::getInt('quantity',$min_quantity); ?>" class="hikashop_product_quantity_field" name="quantity" onchange="hikashopCheckQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);" /> </div> <div class="hikashop_product_quantity_div hikashop_product_quantity_add_to_cart_div hikashop_product_quantity_add_to_cart_div_select"> <?php echo $html; ?> </div> <?php break; case 'show_select_price': if(!$max_quantity) $max_quantity = (int)$min_quantity * 15; ?> <div class="hikashop_product_quantity_div hikashop_product_quantity_input_div_select"> <select id="hikashop_product_quantity_select_<?php echo $i; ?>" onchange="var id = this.id.replace('select','field'); document.getElementById(id).value = this.value;"> <?php $pricesSet = array(); foreach($this->row->prices as $price){ if($price->price_min_quantity == 0) $price->price_min_quantity = 1; if(in_array($price->price_min_quantity,$pricesSet) || $price->price_min_quantity < $min_quantity || $price->price_min_quantity > $max_quantity) continue; $pricesSet[] = $price->price_min_quantity; echo '<option value="'.$price->price_min_quantity.'">'.$price->price_min_quantity.'</option>'; } if(empty($pricesSet)){ for($j = $min_quantity; $j <= $max_quantity; $j += $min_quantity){ echo '<option value="'.$j.'">'.$j.'</option>'; } } ?> </select> <input id="hikashop_product_quantity_field_<?php echo $i; ?>" type="hidden" value="<?php echo JRequest::getInt('quantity',$min_quantity); ?>" class="hikashop_product_quantity_field" name="quantity" onchange="hikashopCheckQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);" /> </div> <div class="hikashop_product_quantity_div hikashop_product_quantity_add_to_cart_div hikashop_product_quantity_add_to_cart_div_select"> <?php echo $html; ?> </div> <?php break; case 'show_simple': ?> <input id="hikashop_product_quantity_field_<?php echo $i; ?>" type="hidden" value="<?php echo JRequest::getInt('quantity',$min_quantity); ?>" class="hikashop_product_quantity_field" name="quantity" /> <div class="hikashop_product_quantity_div hikashop_product_quantity_add_to_cart_div hikashop_product_quantity_add_to_cart_div_simple"> <?php echo $html; ?> </div> <?php break; case 'show_leftright': ?> <div class="input-prepend input-append hikashop_product_quantity_div hikashop_product_quantity_change_div_leftright"> <span class="add-on"> <a id="hikashop_product_quantity_field_change_plus_<?php echo $i; ?>" class="hikashop_product_quantity_field_change_plus hikashop_product_quantity_field_change" href="#" onclick="return hikashopQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',1,<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);">+</a> </span> <input id="hikashop_product_quantity_field_<?php echo $i; ?>" type="text" value="<?php echo JRequest::getInt('quantity',$min_quantity); ?>" class="hikashop_product_quantity_field" name="quantity" onchange="hikashopCheckQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);" /> <span class="add-on"> <a id="hikashop_product_quantity_field_change_minus_<?php echo $i; ?>" class="hikashop_product_quantity_field_change_minus hikashop_product_quantity_field_change" href="#" onclick="return hikashopQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',0,<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);">&ndash;</a> </span> </div> <div class="hikashop_product_quantity_div hikashop_product_quantity_add_to_cart_div hikashop_product_quantity_add_to_cart_div_leftright"> <?php echo $html; ?> </div> <?php break; case 'show_simplified': ?> <div class="hikashop_product_quantity_div hikashop_product_quantity_input_div_simplified"> <input id="hikashop_product_quantity_field_<?php echo $i; ?>" type="text" value="<?php echo JRequest::getInt('quantity',$min_quantity); ?>" class="hikashop_product_quantity_field" name="quantity" onchange="hikashopCheckQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);" /> </div> <div class="hikashop_product_quantity_div hikashop_product_quantity_add_to_cart_div hikashop_product_quantity_add_to_cart_div_simplified"> <?php echo $html; ?> </div> <?php break; case 'show_default_div': ?> <div class="hikashop_product_quantity_div hikashop_product_quantity_input_div_default"> <input id="hikashop_product_quantity_field_<?php echo $i; ?>" type="text" value="<?php echo JRequest::getInt('quantity',$min_quantity); ?>" class="hikashop_product_quantity_field" name="quantity" onchange="hikashopCheckQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);" /> </div> <div class="hikashop_product_quantity_div hikashop_product_quantity_change_div_default"> <div class="hikashop_product_quantity_change_div_plus_default"> <a id="hikashop_product_quantity_field_change_plus_<?php echo $i; ?>" class="hikashop_product_quantity_field_change_plus hikashop_product_quantity_field_change" href="#" onclick="return hikashopQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',1,<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);">+</a> </div> <div class="hikashop_product_quantity_change_div_minus_default"> <a id="hikashop_product_quantity_field_change_minus_<?php echo $i; ?>" class="hikashop_product_quantity_field_change_minus hikashop_product_quantity_field_change" href="#" onclick="return hikashopQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',0,<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);">&ndash;</a> </div> </div> <div class="hikashop_product_quantity_div hikashop_product_quantity_add_to_cart_div hikashop_product_quantity_add_to_cart_div_default"> <?php echo $html; ?> </div> <?php break; case 'show_default': ?> <table> <tr> <td rowspan="2"> <input id="hikashop_product_quantity_field_<?php echo $i; ?>" type="text" value="<?php echo JRequest::getInt('quantity',$min_quantity); ?>" class="hikashop_product_quantity_field" name="quantity" onchange="hikashopCheckQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);" /> </td> <td> <a id="hikashop_product_quantity_field_change_plus_<?php echo $i; ?>" class="hikashop_product_quantity_field_change_plus hikashop_product_quantity_field_change" href="#" onclick="return hikashopQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',1,<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);">+</a> </td> <td rowspan="2"> <?php echo $html; ?> </td> </tr> <tr> <td> <a id="hikashop_product_quantity_field_change_minus_<?php echo $i; ?>" class="hikashop_product_quantity_field_change_minus hikashop_product_quantity_field_change" href="#" onclick="return hikashopQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',0,<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);">&ndash;</a> </td> </tr> </table> <?php break; default: if(substr($qLayout,0,14) == 'show_quantity_'){ $doc = JFactory::getDocument(); $app = JFactory::getApplication(); $quantityDisplayType = hikashop_get('type.quantitydisplay'); if($quantityDisplayType->check( $qLayout, $app->getTemplate())){ $controller = new hikashopBridgeController(array('name'=>'product')); $viewType = $doc->getType(); if(!HIKASHOP_PHP5) { $view = & $controller->getView( '', $viewType, ''); } else { $view = $controller->getView( '', $viewType, ''); } $view->setLayout($qLayout); echo $view->loadTemplate(); break; } } ?> <div class="hikashop_product_quantity_div hikashop_product_quantity_input_div_default"> <input id="hikashop_product_quantity_field_<?php echo $i; ?>" type="text" value="<?php echo JRequest::getInt('quantity',$min_quantity); ?>" class="hikashop_product_quantity_field" name="quantity" onchange="hikashopCheckQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);" /> </div> <div class="hikashop_product_quantity_div hikashop_product_quantity_change_div_default"> <div class="hikashop_product_quantity_change_div_plus_default"> <a id="hikashop_product_quantity_field_change_plus_<?php echo $i; ?>" class="hikashop_product_quantity_field_change_plus hikashop_product_quantity_field_change" href="#" onclick="return hikashopQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',1,<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);">+</a> </div> <div class="hikashop_product_quantity_change_div_minus_default"> <a id="hikashop_product_quantity_field_change_minus_<?php echo $i; ?>" class="hikashop_product_quantity_field_change_minus hikashop_product_quantity_field_change" href="#" onclick="return hikashopQuantityChange('hikashop_product_quantity_field_<?php echo $i; ?>',0,<?php echo $max_quantity; ?>,<?php echo $min_quantity; ?>);">&ndash;</a> </div> </div> <div class="hikashop_product_quantity_div hikashop_product_quantity_add_to_cart_div hikashop_product_quantity_add_to_cart_div_default"> <?php echo $html; ?> </div> <?php break; }
If that still does not work, be sure that you are editing the view of the correct template.
Last edit: 10 years 6 months ago by Xavier.
7 years 7 months ago #306006 by softdune
Team Nicolas,
Is this issue fixed? I have the same issue in the current version.
Not feeling like adapting the code, as I assume this is a bug which would be fixed.
I must say, I could enter order qty above 15 until some days ago. Only difference I made is that over the weekend I changed the global setting of the "Qty input method" to show select.
7 years 7 months ago #306015 by nicolas
From what I understand from your message, you changed the quantity input into a dropdown instead of an input field. In that case, the quantity dropdown is limited to 15 by default unless you enter a value in the "To" field of the "quantity per order" setting of your product and in that case, the dropdown will go up to that value.
The issue reported on this thread is that even with the input field, you would be limited to 15 by default and that has been fixed 3 years ago.
7 years 4 weeks ago #312741 by BluepointWebdesign
I reply on this topic.. is in the same question i asume.. I want the default quantity setting in backen see attachment not to be default on unlimited but i like to have this to be set to 1.
how can i get this done??
7 years 3 weeks ago #312742 by nicolas
You can edit the file "form" of the view "product" via the menu Display>Views and add such code at the beginning:
<?php if(empty($this->product->product_id)){ $this->product->product_quantity = 1; } ?>
7 years 3 weeks ago #312751 by BluepointWebdesign
