- Thank you received: 5
Unwished treating my products as variants
8 years 7 months ago #289277
by bolando
Unwished treating my products as variants was created by bolando
-- HikaShop version -- : 3.3.0
-- Joomla version -- : 3.8.5
-- PHP version -- : 7.0
-- Browser(s) name and version -- : Chrome 64
I have 11 products: 9 of them with prices, and 2 of them are shown but they are not available to buy for now.
When I add a normal product to cart, it comes as a variant of this "unpriced" one and the amount to pay is zero.
It happens also with protostar template, I don't have any modifications.
8 years 7 months ago #289283
Replied by nicolas on topic Unwished treating my products as variants
I do see modifications but they probably come from your template, not yourself.
Checking the template is a good first step indeed.
Could you provide screenshots of the settings of a product with the issue and of the unpriced one so that we can get a better picture of the situation ?
Also, try the "check database" button of the HikaShop configuration to check whether there is a problem with the database or not.
8 years 7 months ago #289353
by bolando
Replied by bolando on topic Unwished treating my products as variants
Hey,
I switched now to protostar to prove that the issue is not produced by template. It happens also in protostar.
I attach 3 screenshots:
1) products-prices.jpg - you can see that all published products that are buyable have prices
2) checkout.jpg - you can see that after a product is added to a cart, it loses the price and the title of the product is modified
3) product-unpublished.jpg - you can see that I unpublished one product, whose title appears in screenshot 3
I can give you access to my Joomla, if that will be helpful
8 years 7 months ago - 8 years 7 months ago #289400
by Philip
Replied by Philip on topic Unwished treating my products as variants
Can you provide some Url in order to process some tests by ourself, also provide a step by step process in order to reproduce your issue.
Awaiting news from you.
Last edit: 8 years 7 months ago by Philip.
8 years 7 months ago #289415
by bolando
OK, I sent via Contact Form
8 years 7 months ago #289467
The problem is that you had products which had their product_parent_id not empty.
But a main product is not supposed to have that. Only variants should have that.
Because of that, the system was not able to properly handle these products.
Sometimes they were treated as products and sometimes as variants, leading to these strange behaviors.
I used a mass action on your website to empty the product_parent_id for the main products and it works fine now.
8 years 7 months ago #289518
by bolando
Thank you, now it's OK. But it's strange, because I didn't set any parent_id for any product, every product was addes via backend.
Time to create page: 0.266 seconds
