- Thank you received: 6
Add To Cart Legacy Does Not Show Product In Cart At Check Out
7 years 8 months ago #302779
by fan4chevy
I am using Hikashop Business newest update.
If I turn Checkout Legacy to Yes Recaptcha does not show but the Item in cart at checkout does.
If I turn Checkout Legacy to No The on Checkout the Recaptcha I am not a robot shows but the product in the cart do not show.
I downloaded the hikashop recaptcha as well.
How can I get both recaptcha and the products to show under in list together?
Thank you,
Charles
Thank you,
Charles
7 years 8 months ago #302802
Replied by nicolas on topic Add To Cart Legacy Does Not Show Product In Cart At Check Out
You definitely want to turn off the "checkout legacy" setting.
If you don't get the products on the checkout, please provide a screenshot of the settings under the "checkout" tab of the HikaShop configuration and provide instructions to reproduce the problem along with a link to the shop.
7 years 8 months ago #302848
by fan4chevy
Replied by fan4chevy on topic Add To Cart Legacy Does Not Show Product In Cart At Check Out
7 years 8 months ago #302862
I suppose that you didn't update the Recaptcha plugin you have on your website, and you're actually using a really old version which doesn't support the new checkout.
So simply download again the install package and install it over on your website and it should help:
www.hikashop.com/support/documentation/7...-with-recaptcha.html
7 years 8 months ago - 7 years 8 months ago #302977
by fan4chevy
I downloaded the same recaptcha just now from same link suggested above. However, it does not show under checkout legacy turned off. However, I just discovered that on checkout if you select 'Registration' it appears.
It does not show for guest or login. Maybe log in it shouldn't. However, I think it should for guest where it ask for name and email. It does show for guest when Legacy is on.
In Hikashop Recaptha V2 plug in, I tried access public and guest as well, but no show under guest checkout.
So I did figure something out. If I put for Captcha after Email then it shows for guest. So because guest did not have password, it must not think it needed it.
Last edit: 7 years 8 months ago by fan4chevy.
7 years 8 months ago #303010
That's indeed the case. If you configure your recaptcha plugin to display after the password, since guests don't have a password field, then it doesn't display it.
Time to create page: 0.216 seconds
