Hika cart module not hidden when empty
6 years 9 months ago #313975 by sandvalley2019
-- Joomla version -- : 3.9.13
-- PHP version -- : 7.2.25
-- Browser(s) name and version -- : every browser
-- Error-message(debug-mod must be tuned on) -- : no error message
No error message, but the Hikashop Cart Module ("Winkelmandje") is not hidden, even when I set the "hide when emtpy" option in the module.
6 years 9 months ago #313980 by nicolas
The "the cart is empty" message is removed.
However, you still need the area with the HTML of the cart module so that when you add something to the cart, the ajax process can dynamically update the area with the content of the cart.
Also, the text "Winkelmandje" is the title of the module which is displayed by the template, not HikaShop. If you don't want the the title of the module when the cart is empty, you should turn off the display of the title in the settings of the module, and instead edit the file "cart" of the view "product" via the menu Display>Views and add the title there, before the code:
<?php echo $this->notice_html; if(!empty($this->element->messages)) { foreach($this->element->messages as $msg) { if(empty($msg['type'])) $msg['type'] = 'success'; hikashop_display($msg['msg'], $msg['type']); } }
6 years 9 months ago #314098 by sandvalley2019
Thanks, this works. One more thing: the function $this->countModules( 'moduleposition' ) in my template always return true, even if the cart is empty. But I suppose there needs to be some code in order to add a product dynamicaly via Ajax.
Peter
6 years 9 months ago #314107 by Mohamed Thelji
Hello Peter,
Even if your cart is empty, if you have published your cart module on that position, then that method should return "true" or >1 regardless of the number of products in your cart.
Kind regards,
Mohamed.
The following user(s) said Thank You: sandvalley2019
Time to create page: 0.197 seconds
