- Thank you received: 1
Hika cart module not hidden when empty
- sandvalley2019
6 years 9 months ago #313975
by sandvalley2019
Hika cart module not hidden when empty was created by sandvalley2019
-- Joomla version -- : 3.9.13
-- PHP version -- : 7.2.25
-- Browser(s) name and version -- : every browser
-- Error-message(debug-mod must be tuned on) -- : no error message
No error message, but the Hikashop Cart Module ("Winkelmandje") is not hidden, even when I set the "hide when emtpy" option in the module.
6 years 9 months ago #313980
Replied by nicolas on topic Hika cart module not hidden when empty
The "the cart is empty" message is removed.
However, you still need the area with the HTML of the cart module so that when you add something to the cart, the ajax process can dynamically update the area with the content of the cart.
Also, the text "Winkelmandje" is the title of the module which is displayed by the template, not HikaShop. If you don't want the the title of the module when the cart is empty, you should turn off the display of the title in the settings of the module, and instead edit the file "cart" of the view "product" via the menu Display>Views and add the title there, before the code:
<?php
echo $this->notice_html;
if(!empty($this->element->messages)) {
foreach($this->element->messages as $msg) {
if(empty($msg['type']))
$msg['type'] = 'success';
hikashop_display($msg['msg'], $msg['type']);
- sandvalley2019
6 years 9 months ago #314098
by sandvalley2019
Replied by sandvalley2019 on topic Hika cart module not hidden when empty
Thanks, this works. One more thing: the function $this->countModules( 'moduleposition' ) in my template always return true, even if the cart is empty. But I suppose there needs to be some code in order to add a product dynamicaly via Ajax.
Peter
Peter
- Thank you received: 1778
6 years 9 months ago #314107
by Mohamed Thelji
Replied by Mohamed Thelji on topic Hika cart module not hidden when empty
Hello Peter,
Even if your cart is empty, if you have published your cart module on that position, then that method should return "true" or >1 regardless of the number of products in your cart.
Kind regards,
Mohamed.
Kind regards,
Mohamed.
The following user(s) said Thank You: sandvalley2019
Time to create page: 0.197 seconds
