Administration: Related Products: Display only Published products when adding?
3 years 3 months ago #353620
by jazzmang
Administration: Related Products: Display only Published products when adding? was created by jazzmang
-- HikaShop version -- : 4.7.4
-- Joomla version -- : 3.10.12
-- PHP version -- : 8.0.29
-- Browser(s) name and version -- : n/a
There appears to be no way to tell if a product is published when adding Related Products in the Administration area while editing a product.
Is there any way to filter unpublished or color-code them?
Otherwise, staff users cannot tell without manually checking the related products' status in another window.
When there are over 1000 products that have accumulated over the years, it becomes a problem.
It would be nice to have filter options at this level or, at the very least, color-coding them (red/green).
3 years 3 months ago #353622
Replied by nicolas on topic Administration: Related Products: Display only Published products when adding?
There is no option to filter them. But color coding can be added quite easily.
To do that, you first need to edit the product / form view file via the menu Display>Views. There, you can find this block of code which displays the related products option:
There, below the line:
you can add the line:
That way, in the selector tree, each product name will be surrounded by a span with either the class product_published_0 or the class product_published_1
Then, you can add a piece of CSS to your backend template ( joomlaforever.com/overrides/override-the...e-cache-admin-module ) for these classes. For example:
will display a light red background for unpublished products.
if(hikashop_acl('product/edit/related')) { ?>
<dt class="hikashop_product_related"><label for="data_product_related_text"><?php echo JText::_('RELATED_PRODUCTS'); ?></label></dt>
<dd class="hikashop_product_related"><?php
echo $this->nameboxType->display(
'data[product][related]',
@$this->product->related,
hikashopNameboxType::NAMEBOX_MULTIPLE,
'product',
array(
'delete' => true,
'sort' => true,
'default_text' => '<em>'.JText::_('HIKA_NONE').'</em>',
?></dd>
<?php
'displayFormat' => '<span class="product_published_{product_published}">[{product_id}] {product_name}</span>',
.product_published_0{ background-color: #ffdddd; }
